Old 08-27-2009, 07:10 PM   #1 (permalink)
94BlueTracker is on a distinguished road
Default A few questions about my tracker
Hello
Im new here, I just bought a 94 tracker 2WD Made in USA
I have a few questions...
Has anyone had any problems with the temperature Bar(it slides either to blue or red) thing not wanting to go past have way towards red side? if so whats causing it and how do you fix it?
anyone have a fix for the door hinges cause the doors like to sag? I dont know if this is a common problem.
also does anyone know were to buy a trailer hitch kit? so i can put one on my tracker because it didnt come with one
thank you
1994 Geo Tracker
2WD
2 Door
Canada
94BlueTracker is offline   Reply With Quote
Old 08-27-2009, 08:01 PM   #2 (permalink)
ok, the engine temp guage.
test it. off my sensor test page
coolant gauge test
hinges. they ran dry and rusted the pins. buy new ones at suzuki or get off wreck.
the trailer hitch is sold everywhere, even on amazon.
google suzuki trailer hitch, hits galore
and the wiring , i used this walmart
trailers
Old 08-27-2009, 08:31 PM   #3 (permalink)
riley is on a distinguished road
I bought hinges from these guys for less than $6.00 each, they also have door handles etc. I just ordered fenders best prices
I have found.
Body Parts | Auto Repair | Automotive/Truck Store - CarBodyParts.net
you may have to copy and paste address.
riley is offline   Reply With Quote
Old 08-27-2009, 10:58 PM   #4 (permalink)
i meant the lever, that you slide to either make it cold or hot. it wont go past a certain point. it like gets stuck or something.
1994 Geo Tracker
2WD
2 Door
Canada
Old 08-27-2009, 10:59 PM   #5 (permalink)
corpseal's Avatar
corpseal is on a distinguished road
Regarding the temperature control for your climate control system, the best thing to do is stick your head down by pedals, and look for the various cables feeding the heater distribution box. Then watch and listen as you move each of the heater and ac controls, and especially the temperature control-you should be able to easily spot the problem. The cable either needs adjusting, or it has something like a floor mat or carpet blocking the full travel of the mechanism.
91 Sidekick 4dr, 1.6 8v, 4speed, 4wd, 48states; Hella lowbeam auxiliary lights; K&N air filter; Calmini anti-sway bars; oem style luggage rack and basket($15 steal from ebay); Firestone Destination ATX tires
corpseal is offline   Reply With Quote
Old 08-27-2009, 11:37 PM   #6 (permalink)
corpseal is ON TRACK.
it just cables , 1 for 1 .
Old 08-28-2009, 12:02 AM   #7 (permalink)
sounds easy enough ill give it a try.
anyone ever fix the door hinge, were the bolts start to come out of the body from rusting and cause the doors to sage? any good ideas to fix that?
1994 Geo Tracker
2WD
2 Door
Canada
Old 08-28-2009, 11:45 AM   #8 (permalink)
yours asking how to fix a hinge ,that the bolts hold on and these bolts
go into the body and afix to body imbedded nuts.?
this nuts or the area sorruounding them has failed due to rust.?
you need a body man (shop). that is difficult area to repair.
if the metals gone, its gone.
only solution is to replace the metal.
one could cut out a good section from a wreck, and then take it to your car
and do a rev. cut of same and tack it in with tig weld and then finish it.
Old 08-28-2009, 01:29 PM   #9 (permalink)
one more question
will parts from a 97 tracker fit on a 94 tracker?
1994 Geo Tracker
2WD
2 Door
Canada
Old 08-28-2009, 02:38 PM   #10 (permalink)
that is a hard question.
the answer is yes and no.
what parts.?
there are 1000s of parts,
body, trim, driveline, suspension, motor, tranny , axles, gearsets,
some are, some arent.
no one has a list of every new part ,for each newer year.
but ask a specific question. and get an answer.
no list.
harness and ECU's vastly diff. motors must both be 16v. (you never ID the motor)
IN 96 many of the splines in the drive line changed. so that is an issue.
many diff. trim parts, many suttle body changes.
the 97 many have ABS and that is diff. diff brakes, diff hub parts, etc.
the 97 will have Airbags, this changes lots of things.
that is an idea
