this is all in the fsm ( can send you it , just ask, and is on ActsFaqs page PDF) free to anyone.
it says, press off bearings after the locking collar is removed
then it says.
make sure there is no wear or brinelling . bluing or discoloration. or bent.
there must be no damage to any of the machined surfaces.
if you tourch off the collar and over heat the axle this causes , annealing .
this makes the suface soft and the seal just digs into it.
the steps are clear but there is craft and art to working on axles , bearings seals and gears. Best is to take the axle to a quality machine shop and ask them to put in new seals and evaluate the condition, ( experienced eye balls , not just labor)
when things go wrong.
i like this link, shows how complex an axle is and how many things can go wrong.
some things are hair pullers.
Rear Axle
actsfaqs is off line, they are moving server. shucks.
http://www.kick-fix.com/
