you wired it to the wrong circuits.
there is a trailer connector in the main harness behind the left rear tail light.
here is the correct adaptor for 5 wire car to 4 wire trailer.
trailers
$13 bucks and 30 minutes.
you wired in the the main power feed. never ever do that.
there are other systems too, that use the cars wiring(above ) and use it as only a signal this is called buffererd trailer lighting. and it needs a power source.
the best source is a direct wire to the battery with your own fuse.
its says that in the instructions.
never connect the DOME< FI , TAIL FUSE ever.
you could have used the radio fuse and now car would at least run.
if you need a power distrabution, try this.
piick something safe.
here is my power page
see the last link, that is your car.
stay away from, the fuses marked with CANT live with out words.
like ECU, memory, ABS, FI, and others so obvious. see them?
mine is a $10 diode gating trailer box . so useds the cars lighting directly.
the buffered kind , must have its own power feed.
the best way to do that IS MAKE ONE from scratch.
at Fuse #3 or directly to the battery, Id go directly with a 20 amp inline (at bat) fuse.
then if you ground out the trailer ckts. then you dont kill ANYTHING ELSE in the car.
think of it as extending the main buss on top. that makes my idea simple.
hope that helps. Use bills comments on gage.
fires suck.
