will not shift down .
ok , your basic tranny is ok, and can be driven with the TCM removed. (unplugged)
4speed only.
drive hard in manual mode, as the FSM states. no slips , basics are ok.
but down shifting, that takes brains.
IIRC:
the TCM must detect the Throttle cut (kick down fail) end to end must be good.
and TAIL shaft speeds dropping (tachomter on tail shaft, VSS#2 tranny )
TPS cut. (it sees that too) LOOK at TCM inputs, see them. Any can be bad.
Engine speed and load is communicated from ECU to TCM. or using todays parlance.
PCM to BCM (power train control module to body controller.)
the TCM(BCM) sees your cut fuel and begins to down shift.
there is a engine braking section in the fSM on this tranny, diagnosis.
there is chart in the FSM that shows the rules for the shift points up and down.
rpms, etc.
THIS IS an electronic shifted tranny , and is missing many of the parts that a 3sp would have.
THE TCM is either not seeing the trasition or the solenoid is not obeying the down shift.
my insticts say its not a bad solenoid.
that the tcm just has to blame something for the failure to drop and cant guess correctly. Par for the course on TCMs.
May be the TCM discovers it is LATE to shift. can cant understand why.
bad inputs? intermittant Inputs, then bingo the are good.
im no tranny expert but i understand the brain a bit.
Id make sure the tranny is missing no ground straps and the battery to body grounds are all perfect.
that is my take on this tranny.
