Hello to all..... newbie here. I have read and received a lot of excellent posts here that have helped me tremendously learning about this vehicle. Alas, so far I am unable to solve the problem.
1991 Tracker, 1.6L, TBI 5 spd, 4wd, manual
A friend recently bought this vehicle and has had quite a few problems and she has replaced the alternator, distributor cap, new plug wires and plugs, starter.
Battery checked at local auto parts store today and is ok.
The car will almost always start if you leave it set for 24 hours... no gas, just turn key and fires up. It then dies within 20 seconds. The only way to start it now (and only briefly) is to WOT and unflood. Chugs and dies. The only trouble code so far is 44 which I believe is TPS. I checked the TPS and the pot side is acting strange, bouncing around. Ordered a new TPS today (ouch!... no local used part dealers had any)
I was able yesterday to play with cold air intake by opening up the IAC thermo a little and got it to fire up and run like a bat out of hell for about a minute... kind of seemed like something freed up and blew out some black smoke.
Iac.. took it off and gave it 12 v and can hear it snap open. Cleaned it and put it back on.
Iac thermo ...took off end cap with 3 screws and can move the plunger freely. Gave it a couple squirts of cleaner .
Egr main. . can move plunger with fingers. seems to hold vacuum ok.
dashpot... hooked up vaccum and it retracts and holds fine.
ECT ohms seem within range
key on you can hear fuel pump and it shuts off within 2 secs.
fuel injector shows 2 ohms. Took it out and sprayed some cleaner on it.
Tried looking down horn with key on to see spray but don't see a spray. Smell gas when cranking though.
fuel pressure regulator with vacuum applied seems to be ok ( notice pressure change)
MAP .. checks out ok... can blow through the small filter as well.
Computer... Took it out and opened it up. It is a remanufactured and looks like new caps have been put in. Normally sends a code 12 except for the occasional 44.
Things I have not done.
Did not change fuel filter..
connections are so badly rusted I am afraid I will break them) I cheated and put a T in right before the throttle body so I could check fuel pressure. Pressure is 32 with key on.
Have not checked compression (don't have that tool yet)
I assume it is flooding out since I smell gas and only way to get it to fire is WOT.
Thanks for listening and any ideas of new things to try would be most appreciated.
