Old 08-20-2009, 07:09 PM   #1 (permalink)
mallor05 is on a distinguished road
Default 94 geo tracker wheel hub
Does anyone know of a good website for a front wheel hub assembly? I am looking for an assembly that has the bearings and seals included.
mallor05 is offline   Reply With Quote
Old 08-20-2009, 07:34 PM   #2 (permalink)
Read on...
Awesome site. The KickFix Repair Pages, for Sidekicks and Trackers
Richard Craneum is offline   Reply With Quote
Old 08-20-2009, 08:36 PM   #3 (permalink)
all the seals and bearing are sold , at all auto stores.
napa stocks them.
csk.com
rockauto.com
y name it.
never seen a preload hub.
or are you talking the locking hub caps. ? not bearing hubs.
Old 08-21-2009, 03:29 PM   #4 (permalink)
Default hub assembly
No, I am talking about the actual wheel hub. I found one on rockauto.com and they had it listed as hub/wheel bearing assembly. I got it yesterday and the damn thing only consisted of the hub. I am probably going to get the parts through a different site clearlyauto.com, their catalog is easier to use and prices are slightly cheaper.
napa stocks them.
csk.com
rockauto.com
y name it.
Old 08-21-2009, 08:58 PM   #5 (permalink)
use bearings you want,
good luck with that.
Old 08-22-2009, 11:16 AM   #6 (permalink)
I have a 94 tracker 4WD automatic. I ended up getting the bearings and seals through clearlyauto.com I have used their website in the past, but they did not carry the hub, so I went with rockauto instead. As for my car, it's my left front wheel that is wobbly. I had to have it inspected and it was rejected for it. A mechanic had checked it out and determined that it was the wheel bearing. I ended buying both the wheel and axle bearing, just in case.
Old 08-22-2009, 12:41 PM   #7 (permalink)
they just press out.
only hitch is having a real tool to tighten the bearing clocking ring nut.
155- 170 ft/lbs , of torque needed on these crush type bearings.
if not set right they all fail at 3000 miles or less.
then must not be adjusted like a cheap trailer.
see my bearing page for front hubs.
Old 08-22-2009, 01:04 PM   #8 (permalink)
I am right on it! I have already read and downloaded your information, so that I can give it to the mechanic. Thank you very much for all the help! Greatly appreciated! Speaking of help, do you know where I can find a new bulb for my automatic shifter? The damn thing was coming on and off and now is completely dead. I had pulled the center console apart, checked the wiring and found that the bulb is burnt out. It has some sort of green coating on it, and have not been able to find a replacement. Can I use just any bulb or ?
