Originally Posted by jtgh
ok.
dont know stock. fan spec, not in the book. guess at 7amps.
but relay is good for 15amps usually.
so fan 10amps is ok.
if the relay dont like fan it will fail.
the wiring is good to 15amps.
discount,
see my page, see last section at bottom says "PARTS"
so i should be ok using existing wires?
i was thinking using using the existing wires to activate a 30 amp relay and power straight from bat using maybe a 10ga
first method sound good cause i don't have to spend on a relay,wires plus less time installing
