Old 08-19-2009, 05:15 PM   #1 (permalink)
notomorrow is on a distinguished road
Default Starting trouble
so my car is cranking over, but not as fast as it should be. I just replaced the starter and the cables coming off the battery with no luck. After cranking it a couple times the wires on the starter start to smoke a bit. The car is a suzuki sidekick 1991 1.6 tbi.
notomorrow is offline   Reply With Quote
Old 08-19-2009, 05:36 PM   #2 (permalink)
new starter,
and
Brand new battery cables? too ?
what wires smoke, no way you smoked those huge battery cables. I dont believe that.
91 TBI
the negative battery cable starts at the minus terminal of the battery and attaches
to the top mounting bolt of the starter
came that way , new. ( no other connections allowed, only direct to starter , can answer why)
if that cable is bad all the body ground wires will burn.
want to fix it , lets test it.
throwning parts rarely works.
here are the critical grounds.
common-failures
here is the no crank page.
slow cranking , can be a bad battery.
but it can just as equally be a resistave or bad power distrution system.
easy as pie , after 18years.
no crank or smoke crank.
Engine-will-not-crank-over
Old 08-19-2009, 06:19 PM   #3 (permalink)
batteries good had it charging all day yesterday just to make sure even though it is a new battery.Any thing thats connected to the started that is not metal is smoking because the starter is getting hot.
Old 08-19-2009, 07:21 PM   #4 (permalink)
there key word,what exactly is getting hot.
starter casing.
if true engine is mostly likely hydra-locked. or plain seized. (bad ring gear , rare)
remove spark plugs , see what happens while cranking.
green juice flying and fast crank speed.
this is 8v and is free running motor so no valve jammed to pistons.
or much worse.
