Old 07-30-2009, 12:22 PM   #1 (permalink)
luigi daniel is on a distinguished road
Default 95 Tracker engine speed oscilating
Hello all !
Another symptom without answer : when keeping the throttle constant to 1800rpm, the engine speed drops to 1500 then back to 1800 and back to 1500 and so on...... any reason why ?
95 Tracker 1.6l 16V 4WD automatic
95 Tracker 1.6l , 16v, Auto , 4WD
luigi daniel is offline   Reply With Quote
Old 07-30-2009, 01:04 PM   #2 (permalink)
yes,
could be lean motor but..
top reason
1: TPS switch failing or not calibrated correctly
This switch on your car is closing (wrongly) while cruising , and then the ECU says.
hey this guy/gal wants to control idle at 1800 rpm.
ok , im a stupid computer , so Il'' just try that.
yup, it does.
there are lots of other reasons, but this is common.
Old 07-30-2009, 01:26 PM   #3 (permalink)
Thank you again, Jerry !
Yes, this makes sense, as it happens for this particular throttle position only ;
I will check the TPS first.
Old 07-30-2009, 01:40 PM   #4 (permalink)
see my tps cal page.
TPS testing
just a 99cent feeler guage and ohm meter.
dont let the actual ohms variances fool you, it just need to be below 300 at idle
and infinity above idle, using the feelers.
it is normal for the ohms to drift, at idle pos. 45-70 ,ect.
