HI ALL,anyone have ever heard of problem with the ECM of a 4 cylinders,maunal transmission?
i have a problem of "pingkage ".i changed from ragular too premium gaz,,,did not change a bit.
changer the 2 OS2 sensor,no change
i change the plug,,,
i heard about a problem of ECM,is it true?
is there any recall ?
thnaks for your help
Gervais
Pinging , Detonation is what it is and is very destructive.
what motor is this , ?
is the check engine lamp on, or worse flashing.
if it is Pinging, dont run it, do not put heavy loads on it. None.
this motor is not known of pinging. (due to combustioin chamber designs)
but if you have super lean mixtures. ? maybe.
does it ping, ?
hot only
cold only
all the time
or just on hills.
onething that can make it ping is if it is overheating for any reason.
make sure radiator is full and 50/50 antifreeze. and RAD cap is good.
another thing is EGR malfunction.
explain driving conditions before and just after the pings?
"No it is not on"
"at any time it would ping"
does it ping, ? "everytime you change shift speed you would hear the little PING sound and cold or hot,,,,,
hot only
cold only
all the time
or just on hills.
"EGR malfunction" i did not think about her,,,,,,,,,,yes
i have 108,000 km on it,always well maintain,always synthetic oil in engine,differential,transmission,transfercase .
NGK plug
i really dont know,my freinds have one just like me and it does not ping,,,,
i may swap the ECM or check his Parts number
what you got
what motor
and if you have a dizzy did you unclamp it and spin it.
no.
is the IGN timing off. then the belt is slipped. if you have a belt....
sigh.
PS: our Vitara 420 has chain drive , cam, DIS (no dizzy ) COP motor.
or 416 motor is belt drive, and COP, no dizzy ,
2002
you know what,i am working all day long ok,i dont read email during the day,,,,,,,
yes my engine is a 2.0 liter
i sent an email at Suzuki Canada,they told me that
there was no TSB on my serial number.
i had acces at Mitchell support on the web and i could see that there was a TSB on the ECM of these engine.
And if your update is done you would have a sticker on the door of the glove box and i dont have.
i sent them the pdf of the bulletin to them,,,,i am still waiting their response
sorry we were just pulling your chain, joking. no stress here.
this is nice motor, and if you are not ignoring a huge amount of chain noise
then it hasnt slipped. it will thrash mad, if bad.. the chain or tensionor. which can go bad at 150k. or more. if you fix tensioner first , you save the chains. when it goes bad.
I looked at Mitchell. those TSB are for updating the FACTORY ECU PROPRAMMING equipment. "pass thru programming"
no TSB posted at all for ECU issues on 2002s. that era. cant see them.
see All TSB by number to right at Mitchells.
this are a few recalls. on for fuel pressure reg. Grand vitara not reg. vitara.2002
id not expect any ecu problems since they have made this since 1996 and ever before on esteems. long history of solid reliablity. really.
your car is busted lets fix it. the ecu is fine, 99.99 %.
