Old 07-21-2009, 08:54 PM   #1 (permalink)
joefryday is on a distinguished road
Default weird park light issue...
...they stay on. license plate light also. unless i pull the fuse or unhook the battery. any ideas? any help is appreciated. jason...
joefryday is offline   Reply With Quote
Old 07-21-2009, 10:31 PM   #2 (permalink)
combo switch is bad.
head/lights and parking lamps are all hot at all times circuit (safety)
so if the switch fails closed you get light. 24/7 or till battery dies.
pull steering wheel.
'pull combo.
some can be fixed in car , if you can get switch apart insitu.
a deft touch, that takes,,,,,
find a spare at wrecking yards. new is $$$$
Old 07-21-2009, 10:32 PM   #3 (permalink)
alt.
is something has shorted 12v to the park feed. anything is possible.
Old 07-21-2009, 11:58 PM   #4 (permalink)
...the headlights go off. just parks and license plate stay on like you said 24/7. combo switch for sure? do appreciate the response. i like cheap easy fixes, maybe a toggle switch... thanks, jason.
Old 07-22-2009, 12:45 AM   #5 (permalink)
whoa. just looked up that switch $873 at autozone on a 96. i'm not much on fixing things but i have a dude who is. is it possible to bypass the golden switch? that would sure make life more affordable. thanks for your expertise, i'll hafta fed ex you a cold beer...
Old 07-22-2009, 01:30 PM   #6 (permalink)
all switches can be bypassed
procecure.
pull wire that feeds park from down stream side of combo switch main conn.
take wire , and run it to SPST toggle switch (or any that you fancy)
now wire it to the new switch (whereever) and put other side to , tail fuse.
go to same fuse that old wires go now.
tell exact car will give exact schematic and a new drawing just for you.
most just find a wrecked doner car. but this works too.
give me (please)
year,
model, motor size 1.6 right and valve count 8 or 16 , and tranmssion type.
and number of doors. this really helps. 4wd or 2wd?
all drawings are indexed by those parameters.
see my sig.?
Old 07-22-2009, 01:59 PM   #7 (permalink)
thanks pal. you're doing a great job taking care of us technically-challenged. i actually got lucky and bought a used combo switch on ebay for $60 shipped. 96, 16v, 4x4. i may even be able to handle replacing it myself. thanks again. jason...
Old 07-29-2009, 05:11 PM   #8 (permalink)
...my tracker doesn't have cruise control. my new combo switch does. thought i'd ask before digging a hole, will it still fit? thanks again for the expertise. jason...
Old 07-30-2009, 12:12 PM   #9 (permalink)
it will have a Start Resume switch.
unplugging the combo switch, and see if lights go out, is pretty condeming of same.
im worried about the connector.
checking now.
Old 07-30-2009, 12:28 PM   #10 (permalink)
lots of variables. No profile, so will guess a t 95
year car ?
cruise , tilt wheel. , DRL, and country ?
95 shows. uSA, Master PL
2 combo switchs, reg. and cruise.
the question is the connnector,
does it pick up pins in the diff harness?
i dont see custom harness, so i must pick up extra pins for cruise.
best i can figure.
BINGO found the connector drawing.
the main conn. is the same (includes canadian DRL) and has seperate connector for cruise.
your new switch will work, i think.
hope that helps
fill out your profile, and it gets way easier.
country , and car spec. no personal data.
