The engine is coated with old and gummed up oil. The oil also comes from the back side and is all over the tranny. However, does not drips on the ground, so I am assuming that is not really a major problem, just a nuisance.
Since I bought it used might as well replace the Timing Belt assuming that never been done. So during the process, the Valve cover gasket needs replacement and god's know what.
My questions are...
What parts can I replace when I get that far?
I know water pump is one and gasket for it.
Wondering about O Rings and other Doo-Dahs.
By the way, Auto Zone has the Dayco T-Belt for $19.99 where I live
There is a shopping list that I can go by?
I hate to run to the Part Store for some that I forgot.
I have not fixed the Popping Sound / Shaking when the throttle is feathered, but is less now.
As hunch, is possible the T-Belt was replaced and not followed procedure.
I read
Jerrys main sidekick page website and has excellent info. The procedure that tells how to change the T-Belt I would guess it wrong. So if any mechanic did it and assumed the belt is like any belt as long you do not moved the camshaft and crankshaft would be ok to install. It could be a jumped by one tooth and that explains the shaking and the popping sound.
Anyway, I am going to clean the injector and go from there too. Could be a combination of things.
