I've known that my rig has a slow oil leak for a little bit now but yesterday when i was changing my oil i noticed it was coming from right where the engine and tranny meet. that wouldnt be anything other than a rear main right? ( no oil on top of engine, only bottom) and second, what would be easier? pulling the engine or pulling the tranny and gettting under the car? and last, ive never done one of these before. how do i get the old seal out and new one in? i dont have to pull the engine apart do i?
92 geo tracker tin top, bone stock except for decent sound system, a set of hella 500's, and a badly peeling clear coat.
Very interested in this thread. Tired of seeing the drips in the driveway.
The oil pan on my '91 appears to be leaking as well. I'm not sure if I can change that oil pan gasket with the engine still in -and the front axle still in as well.
I need to take the Tracker to the car wash and do the degreaser cleaning - figure out exactly where its leaking from. Potentially its the oil pan gasket or the front main seal.
MarkB.NV
1991 Tracker, 8valve 1.6L, 5 spd, 4x4, 2 door, soft-top, 103,xxx miles, w/ 2 in suspension 2 in body lift, 30x9.5/15 MT tires.
good call bill. looks like it is coming from the dizzy (thats a relief). but does anyone have the part number for the o ring? none of the parts stores around here can find it. or is it just a standard o ring? if so, what size?
mark. for your pan gasket, it is usually possible to loosen motor mounts and lift the engine up a couple inches. just enough to drop the pan down (a couple inches) and shimmy a new gasket in there. but let me tell you its a pain in the ass! ive done this on several different cars. just have a beer on hand and be prepared to get very pissed off at your rig
ok, so just to make sure before i order them are these the correct o rings? they dont match your part number exactly but i think im looking at the right ones:
-035 V75 (2-1/4 ID X 2-3/8 OD X 1/16 W)
-118 V75 (7/8 ID X 1-1/16 OD X 3/32 W)
is that right? i cant believe their so cheap! my local suzuki dealer wanted like $12 for those 2!
and speaking of valve cover gaskets, you know any sites where i can get a $1 gasket?
lol, im probably dreaming right?
