I did some maintenance on my son's Tracker.
Is a 94, 8v, Manual with TBI.
No ( CEL ) Check Engine Light/Engine Service Light is ON .
We replaced the Air filter, was full of leaves and dirt, pretty clogged up. Replaced the Spark Plug wires with Duralast (Auto Zone brand) that are made in USA (no Chinese crap). Replaced the Spark Plugs, the plug that was installed were Autolite and replaced them with Bosch Platinum (used them on a Geo Metro before and worked fine).
When I start the engine, it runs rough in idle. If you feather the throttle, it backfire by the intake. Once it picks up speed (RPMs) seems to run smooth. The exhaust starts to smell in the same way burnt powder does. I think is Sulfure on this case and you can hear from the tail pipe like is missing.
Ran the engine until reached normal Temp.
BTW, is that about 1/2 way on the gauge?
I removed the Dome fuse, thinking the engine was breathing better since the filter was new vs the old one and making it run richer and the engine adjusted to it. So by resetting the computer I was hoping to go to a nominal settings. Seems not to help.
I am wondering what went wrong? It could be the plugs? I doubt it but will not be surprised if is. I kept the old ones and might try them tomorrow to see if that is the problem.
My thinking is the engine is running leaner and have not adjusted to the new amount of air. But should it learned by now?
Anyway, any other thoughts on this?
Pics of my Tracker are here
1994 Geo Tracker
In case that I miss some.
Since the thread got lengthy, let me narrow down what I have so far....
Brand new...
Fuel Filter, Air Filter, Oil Filter w/ Oil (Mobil 1), Spark Plugs (Bosch Platinum and tried AC Delco OEM plugs), all Vacuum Hoses, Timing Belt, Rotor/Cap/Wires.
Test done...
MAP Sensor, Ignition Timing (holds at 8 deg), Visual inspection of Key Way for Crank Timing Belt Cog, Fuel Pressure Regulator with hand held pump, Fuel Pressure holds at 39 PSIG, ECU for blown Capacitors, EGR.
Each time I fixed some, the engine seems to run a bit better.
The next new thing is the O Sensor which is on order.
IS FIXED !!!!
SPARK PLUG WIRES WERE BAD !!!!!
As stated before. The engine ran like an old car. Kind of shaky and smooths out after a good warm up. Just need it some TLC. I changed the Plugs, Wires and Air Filter. Just after that, the engine start to run like crap. Shaking and popping when it ran under load. I was thinking, the new Air Filter was giving too much clean air since the old was was really plugged up, so it had the symptoms of a Lean Running engine.
I asked for help here and had tons of helps, great forum !
Check Jerry's Site
The KickFix Repair Pages, for Sidekicks and Trackers a lot of excellent info.
According to the website, I did a lot of checks. From Fuel Pressure (I found I had a bad Fuel Pressure Regulator), EGR Checks, MAP Sensor, Vacuum Test, Timing Belt and Ignition Timing. All seems to checked out. Even I cut the Catalytic Converter to see if it was not plugged.
But I remember that I bought a Spark Plug Wire Set from Auto Zone (by the way, not all they sell is crap) seems to be the root of the problems. I got the OEM type AC/Delco and now runs great.
I forgot about a symptom that occurs when a vehicle is under load and is a Bum Ignition Coil. I had a Honda that did it. But with the modern cars, I have never encountered and forgot all about it.
The Tracker is a mix of Old and New. So if your car, hesitates, runs somewhat rough, no power at all it could be bad Spark Plug Wires (I think on my case was Coil to Rotor cable), Worn Rotor, Worn Cap.
The wires cost about $29.99 for the OEM at Advance Auto Part
Cap and Rotor was like $8.00 a piece at Auto Zone.
If your Tracker Experience that and you have not replaced any of them, do so, is part of the Maintenance according to the Owner's Manual and is pretty cheap to do.
By the way, Bosch Platinum Plugs seems to run just fine and was only a $1.00 more than the OEM and last way much longer.
