so wires are like, less then 30k old ? or they just look new (looks means nothing on wires)
and did you check the spark at the coil and not check spark at plug wires.
put a spark plug (new any heat range) attacthed directly to the coil. spark shell grounded.
crank motor , must be a blue white powerful flash.
dont touch it , 100,000 volts will happen if this connection opens up.
we do it this way, so the dizzy Cap is out of the picture. ( bad timing, slipped timing belt)
keep in mind, the dizzy makes spark all by itself, I mean, the ECU does not play a role in the generation of spark on 89/90's (samurai style)
so: (thus the flow)
Dizzy CMP >>>>Ignitor>>>coil>>> Dizzy cap>>>rotor>>>spark wires >>> sparks.
see this? now check the COIL output , CUTS the problem in half.
nothing like a binary search , for sure.
