I need some advice for my 1995 suzuki sidekick jx...
it will run ok for a while, then once it warms up it stops running... bogs down, idles real low, stalls, then eventually won't start at all... non responsive gas pedal... light gas pedal pressure helps a little but not much...
what should i do? i was told ignition coil but i want to be sure and don't have an ohmeter. again, it's only when it's hot.... vehicle has a new/used engine... reltively new plugs and wires... new fuel pump/filter...
check engine light has been on forever..
im not quite sure, i just got a new multimeter and was playing around and thats one of the things i testes and i dont remember exactly but i think i got somewhere around 1.3-1.5 ohms on the primary. plus i dont think the coil should act any diffrently when the engines cold rather than hot. im still think its an 02 sensor.
i dont know how to check the o2 with a multimeter but if your car were obd2 (96 +) you could just read the info of a scantool
92 geo tracker tin top, bone stock except for decent sound system, a set of hella 500's, and a badly peeling clear coat.
ok , first , tell us, what motor your have,?? we now know only the body.
16v , 8valve , what?
when the motor stopped, the first thing to check is SPARK.
did you lose spark. Use a new spark plug to test spark , any heat range.
NO? spark is good ?. then:
then try WOT, wide open throttle to see if it is flooding. (WOT + cranking = no injections of fuel called unflood mode)
look at the plugs, are they wet with fuel? soaked.
if the plugs are dry , try test fuel. (instant spray in to Evap nipple (what motor?)
if motor is flooding, (smell it , see black smoke at tail pipe?) then
unplug injector harnness (all for come to a single point and a conn.)
unplug this and if motor wants to run , even a little , you have leaking injectors.
key points
Loss of spark
no fuel (dry plugs , test fuel starts car every time when dead)
Flooding. (wet plugs, stinks of raw gas out tail pipe )
once you find out this , trouble shooting can proceed, guessing will cost big $$$
calif cars dont have this switch. ( the smog sticker under hood, tells this data)
PS>
once the NAG is turned off , you will net get only CEL DTC errors, we place a paper clip jumper and out flashes the error codes.
called diagnostic trouble codes.
