Old 07-15-2009, 02:28 PM   #1 (permalink)
obradleyo is on a distinguished road
Default blinkers?
hey guys I posted about my blinkers a long time ago and never got around to getting it fixed. Last time I was told usally its a short because of a hackjob on the trailer lights..... I took that all apart today and looks good.
Heres the symptoms
no blinkers left or right
Blows fuses when key is on not when i flip the lever
Hazords work so bulbs are good
has after market hitch checked wires they look good actually the person did a good job.
so whats next?
Thanks in advance car stats are in my tag
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" TSL's,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca
obradleyo is offline   Reply With Quote
Old 07-15-2009, 02:41 PM   #2 (permalink)
Thiazolium is on a distinguished road
Sounds like you may have a short in the column. Disconnect the battery and diagnose the turn signal stalk switch in the column as a starting point.
Thiazolium is offline   Reply With Quote
Old 07-15-2009, 02:43 PM   #3 (permalink)
What will i be looking for Just loose wires and bad sttuff or do i need to check power comming to and from.
Old 07-15-2009, 04:42 PM   #4 (permalink)
Sure, begin with the obvious - look for damaged components / wiring, then start taking the column apart to test the individual pieces for shorting using a multifunction tester (if you don't have one you can get them at your local electronics shop for cheap).
Old 07-23-2009, 03:42 PM   #5 (permalink)
ok so what voltages need to be comming from where? There are a few wires on the back side if the blinker switch. So what should i do next I'm Totally lost on this one.
Old 07-24-2009, 04:47 PM   #6 (permalink)
Farley is on a distinguished road
Hi, I had those same syntoms with my tracker. I had to take the column apart. There is a mechanism made of white plastic which contains a bunch of coils and bearings which activate the different controls. One of mine was burned out and was shorting with a cable. It just took a little tape and the time to put it all back together. Good luck.
Farley is offline   Reply With Quote
Old 07-24-2009, 05:03 PM   #7 (permalink)
aquanaut20's Avatar
Connect a VOM across the blown fuse teminals (12-20vdc scale), if you have a short will show bat voltage, disconnect circuit until VOM reads 0vdc. This will isolate the section/component causing the problem. Easier than trying to do a visual search.
92 Ford Explorer, 450k
97 Ford Explorer, 360k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 165k
Old 07-28-2009, 01:20 AM   #8 (permalink)
so after inspecting all the blinker wires for a short and found that it was all looking good. I dicided to put a new fuse in to see if i could hear where its shorting at. now they work just fine drove to and from work today no problems.....
