Old 07-14-2009, 04:05 PM   #1 (permalink)
ross_nose is on a distinguished road
Default Stereo Wont remember anything!
HI, bought my suzuki vitara 94 and had some time on my hands so have sorted most probs now apart from, it has an aftermarket stereo which was badly wired in and had a bad earth so i have sorted this but it will not remember anything!! ie stereo settings and radio channels! which is annoying! got told by a mechanic friend to swap the red and yellow wires but after doing this it does remember for a short time but if i leave turned off for say 10mins then start up again it has been reset?! i do have an alarm and immobilizer, didnt know if this had anything to do with it? cheers, ross
ross_nose is offline   Reply With Quote
Old 07-14-2009, 07:40 PM   #2 (permalink)
mtndew's Avatar
Gallery: 7
mtndew is on a distinguished road
no problems starting the car though right? the only other thing i can think of is you either dont have the memory power wire hooked up or its a bad wire with insane amounts of resistance. only other thing i can think of would be the deck itself
92 geo tracker tin top, bone stock except for decent sound system, a set of hella 500's, and a badly peeling clear coat.
mtndew is offline   Reply With Quote
Old 07-14-2009, 10:55 PM   #3 (permalink)
Badgerfan3121's Avatar
Badgerfan3121 is on a distinguished road
i had the same problem no mater what deck i would put in. I just ran a hot power wire from the battery to the player and now it works fine, mine would never save the radio channels, or the time or anything it gets annoying. Try the power wire thing even though you might have a hot wire i tryed the same thing switching them around, but for some reason it just works when i ran a straight wire from battery to cd player.
91' geo tracker 4/4 automatic, new paint job, 16 speakers a rockford 15", flip up LCD touch screen jensen monitor, brush guard, led lighted interior, tinted windows, k&n air intake system, k&n oil filter, , 2" coil spring spacers, 5 1/2'' body lift, shift kit, 2" wheel spacers, cragar black soft 8" rims , bf goodrich tires 235/75/15, custom rock sliders, soon light bar, hood scoops, and 3 inch suspension lift.
Badgerfan3121 is offline   Reply With Quote
Old 07-15-2009, 08:15 AM   #4 (permalink)
i used to have the same problem in my 1994 sierra, was like that when i bought it. 3 months later the wire burnt out (car lost all power and blew smoke out around my knees, dnt think ive ever stopped the car that quick since...) but its fine since then. apparently the mechanics only replaced one wire.
point is, could it be a short somewhere?
whincup is offline   Reply With Quote
Old 07-19-2009, 02:22 PM   #5 (permalink)
Default yeah
yeah i think im gonna go with the idea of a direct wire from battery to the stereo but with a inline fuse for safety, just wondering what ampage fuse i should use? im thinking 10amp, will this be to big/small?
Old 07-20-2009, 09:50 AM   #6 (permalink)
Ya, 10 should be fine mine has an inline fuse on my stereo but im not sure asactly what it is im guessin it a 10 or 15 amp. if not a lil bigger let me know how it goes u could try it be fore going through the hassle of puting it through the fire wall just run a long one around through the window and test it to see.
Old 07-20-2009, 08:52 PM   #7 (permalink)
no 1amp
memory is almost nothing , never overfuse , unless you want trouble.
the memory wire wires to the Dome fuse on all cars.
same as memory wire for ECU.
thats why resettign ecu resets radio.
we have schematics ,just ask.
Old 07-21-2009, 01:20 PM   #8 (permalink)
Hi, um ok well im not sure which fuses the dome ones are?! is this the four inside the top left hand corner of the bonnet bay, next to battery? so i can run a wire from this point to power on stereo?
Old 07-21-2009, 02:47 PM   #9 (permalink)
ah, the fuel panal for all small loads are above the left knee.
those on finder are huge, main feeders.
see words, tail dome, that be it. (one side is wrong)
the other side is.
input to tail dome
is
white /yell wire, heavy
output of TAIL dome is white and goes to ECU and to the RADIO plug.
find radio main connector and find white wire , this is memory wire.
this data is all OEM USA 94, but may be same on yours.
probably is, as this is radio and not lighting which can very greatly.
fuse 13, is tail dome ,hot at all times. as it says.
