Old 07-02-2009, 01:09 AM   #1 (permalink)
Kaoseighty9's Avatar
Kaoseighty9 is on a distinguished road
Default Any one running a After market cone air filter??
i was wondering what kind of difference it would make on a small engine but
im guessing it would have some sort. was wondering if any one has one installed
and where they got it from or name of product.
1998 Zuki Sidekick Sport 4-Wd 5-Spd Manual
2-3/4" lift home made
235/70R16 Goodyear tires
215/85R16 FireStone Destination M/t Ordered!!
Sand Blasted OEM Rims Sprayed Black
( 4 ) Kc 130 Watt 6" Lights (Roof)
( 2 ) Kc 100 Watt 6" Lights (F. Bumper)
)(* War Isn't About Who's Right, It's About Who's Left ! *)(
Kaoseighty9 is offline   Reply With Quote
Old 07-02-2009, 01:52 AM   #2 (permalink)
mtndew's Avatar
Gallery: 7
mtndew is on a distinguished road
if you dont have a maf (earlier models i think) just a an angled piece of pvc pipe and a k&n air filter, and bingo, you have a "cold air" or "ram air" or whatever you want to call it intake
92 geo tracker tin top, bone stock except for decent sound system, a set of hella 500's, and a badly peeling clear coat.
mtndew is offline   Reply With Quote
Old 07-02-2009, 06:47 AM   #3 (permalink)
I'm assuming you have a 16v. Somewhere in this thread Low Range puts on a cone filter. Good luck
"The Tracker" Build - Pirate4x4.Com Bulletin Board
Old 07-02-2009, 11:06 AM   #4 (permalink)
shackwrrr is on a distinguished road
That 98 should have the 1.8
1993 sidekick JLX 4dr
1.6-16v
5speed
USA
shackwrrr is offline   Reply With Quote
Old 07-02-2009, 05:33 PM   #5 (permalink)
ye i have the 1.8L in-line 4
and thanks
Old 07-02-2009, 05:38 PM   #6 (permalink)
oh i was also looking at ther
Hi-Flow Air Intake System
LOW RANGE OFFROAD
why dose it only say 8 valve?
whats the reason it wont work on a 16 valve?
Old 07-02-2009, 06:13 PM   #7 (permalink)
mtndew's Avatar
Gallery: 7
its because of your MAF (mas air flow sensor). i dont know specifically for this car but its usually right after the air box and looks like part of the air tube with a little box and wires coming off of it. you can still do a cone filter set up, but you have to incorperate the MAF into it. its doable but just makes it a little more difficult.
Old 07-02-2009, 07:46 PM   #8 (permalink)
obradleyo is on a distinguished road
i got a cheap-o form the local parts store.
they sell every thing you need to do it to any car with or with out a maF. Mine has the maf sensor they sold a plastic pice for $6.00 to put the sensor in.
and the it was 20 bucks for the filter.
Didn't make a big differance but I was able to drive in 5th again.....
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" TSL's,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca
obradleyo is online now   Reply With Quote
Old 07-02-2009, 10:08 PM   #9 (permalink)
1.8L has MAF , neatly tucked in TB. (throttle body)
it is a poor filter. compared to stock. lets dirt in ,according to independant tests.
and sucks hot are as photo above clearly shows.
it will do on 1 thing, make more power (maybe) at WOT, and at no other time.
after all the throttle limits air at all other times. ( think about the flow)
the stock setup gets better cold air.! trace it, every inch.
but you could pressurize the stock air box by fitting tube from cowl to Air cleaner box.
then youd have SOMETHING. true ram air.
the best things i life are home made.
the reason these sell is because any one 10 years or older can screw it on.
for it to be better, takes work. lots more.
IMHO , and have good company.
Maybe Myth busters will tackle it.
Pop mechanics and SAE.ORG have already.
Old 07-02-2009, 11:25 PM   #10 (permalink)
ah ic well cant expect a 19 year old to know everything.
