Old 07-02-2009, 11:33 PM   #11 (permalink)
onestoptakeaway's Avatar
onestoptakeaway is on a distinguished road
What about getting after market high flow filter that fits into the stock air box ?
onestoptakeaway is offline   Reply With Quote
Old 07-03-2009, 11:22 PM   #12 (permalink)
sure ,same dudes sell the cotton oil marvel sell OEM style too.
just keep in mind , any change in flow ,nets more dirt.
(that is because surface area is hard to increase over stock , see all the pleets?) oEM.
the only better filter ,is bigger and stops more dirt ,while increasing flow, ( only at WIDE OPEN THROTTLE)
cold air is a different , mind set. which is , how to get free pressurized air.
i have a link to a Miata one that nets 5HP on 1.8L motor , NA. WOT only. on a test track.
140HP becomes, 145HP. on this kick, dont expect that.
if you really could make more flow than stock the ECU would go bonkers. (little yes, lots more, no way for free)
Old 07-04-2009, 01:25 AM   #13 (permalink)
mtndew's Avatar
Gallery: 7
mtndew is on a distinguished road
hey kaos, i noticed on your sig you have a home made lift. i sent you a private message asking about it. you should check it out and hit me back
92 geo tracker tin top, bone stock except for decent sound system, a set of hella 500's, and a badly peeling clear coat.
mtndew is offline   Reply With Quote
Old 07-04-2009, 01:46 AM   #14 (permalink)
Mickey_D's Avatar
Mickey_D is on a distinguished road
The previous owner of mine put this silly monstrosity on.
Didn't have the heart to tell him it was an expensive bauble that did nothing for the engine (maybe even harm it with more dirt getting in).
I'm going to be modifying a Jeep Cherokee Safari snorkel to fit in on this one. Some day. When I actually have something resembling money....
1991 US Geo Tracker 1.6L 8V TBI 4X4 hardtop
Mickey_D is offline   Reply With Quote
Old 07-04-2009, 10:41 PM   #15 (permalink)
oil, cold air (not) and tires. my lips are sealed.
Old 07-05-2009, 03:39 AM   #16 (permalink)
Kaoseighty9's Avatar
Kaoseighty9 is on a distinguished road
so your saying even big filters are not worth putting in for extra power?
even if its a little what if your a clean person and clean the filters and
all that regularly alot.
1998 Zuki Sidekick Sport 4-Wd 5-Spd Manual
2-3/4" lift home made
235/70R16 Goodyear tires
215/85R16 FireStone Destination M/t Ordered!!
Sand Blasted OEM Rims Sprayed Black
( 4 ) Kc 130 Watt 6" Lights (Roof)
( 2 ) Kc 100 Watt 6" Lights (F. Bumper)
)(* War Isn't About Who's Right, It's About Who's Left ! *)(
Kaoseighty9 is offline   Reply With Quote
Old 07-05-2009, 11:38 AM   #17 (permalink)
Ole-Boy's Avatar
Ole-Boy is on a distinguished road
Since my motorcycle racing days, my theory has always been like this. The air-intake is only so big. It lets just the right amount of air in to keep it breathing right. True, you can add a bigger filter, but the air still goes through the same size stock intake.
Always remember this. Any time you want more air in, you also have to let more air out. So, that means a bigger carburator, and bigger intake/s (hole) in the carburator manifold. By that time you need to go inside the engine. The cam will need more lift and duration remaining open to allow more air through. And don't forget the other end (exhaust ports) will need to be bored out to continue the same volume of air going-in, as going-out. Then comes the bigger exhaust header, the bigger diameter exhaust. Right out to the end of the tail-pipe.
Hopefully I make some sense in my explanation.
Like jtgh is trying to say, it might look pretty cool. But that's all it does. Why waste the cash under the hood when it does no good.
Drive it...maintain it....enjoy it for what it is. Not for what it's not.
Ole-Boy is offline   Reply With Quote
Old 07-05-2009, 12:16 PM   #18 (permalink)
wow thanks that was perfect explaination
i think i got the point.
Old 07-05-2009, 12:27 PM   #19 (permalink)
ole-boy, said it , in the fewest words.
im saving this link , permalink , nice very nice work.
thanks
Old 07-05-2009, 01:40 PM   #20 (permalink)
Okay. I'll put in M2C... I have to go with the detractors... & as I'm typing this theres an ad up top that says "Guaranteed Horsepower'. Ofc I shant name our respected sponsors. Last I installed a carb on a vehicle was my (now defunct tool shed) '87 Dodge Raider, same as a Mitsu Montero. I replaced the gastly stock electric carb with a Holley Weber. While discussing filter options with the guy I bought the carb from he recommended I go with a paper filter, not cloth. This is a guy who has been building show quality hotrods since they were called hotrods. His words to me: 'They make a great place for the birds to nest once the engine doesn't run anymore.'
I say just use a good quality paper filter that fits the OEM air cleaner. I'm using Purolator Premium Plus in my 16v 1.6 atm (A14869). They call it 'multi fiber' element... it has a cloth like screen before the paper element itself to catch the big crud before the paper. Fits in the OEM cleaner like a glove.
"The Oil Guy' did a review of filters as well, & pretty much came to the same conclusion: cloth filters don't filter as well. Go Go paper!!
Fuzz
Pioneer Sound system
fuzzy1 is offline   Reply With Quote
