Old 06-29-2009, 06:21 AM   #1 (permalink)
wildfire is on a distinguished road
Default timing belt/valve adjustment
I just recently glued down my valve cover on my 91 geo tracker to stop an oil leak.
Now I have my timing belt cover off in the hopes of replacing the camshaft and crankshaft seals that appear to be leaking as well.
Does anyone know if it is absolutely necessary to remove the valve cover again in order to loosen off all my camshaft bolts etc. and set my timing to #4 TDC (which seems ackward), or can I just forgo that procedure and just replace my camshaft sprocket, timing belt etc. orginally set at #1 TDC. thanks...confused!
wildfire is offline   Reply With Quote
Old 06-30-2009, 04:02 PM   #2 (permalink)
Originally Posted by wildfire View Post
I just recently glued down my valve cover on my 91 geo tracker 8v to stop an oil leak.
oops, how you going to lock the cam to do that?
Does anyone know if it is absolutely necessary to remove the valve cover again in order to loosen off all my 1 camshaft cog bolt etc. and set my timing to #4 TDC (which seems ackward?), no , ackward , that is the factory way of doing it.
if you need the factory words, i can send them.
or can I just forgo that procedure and just replace my camshaft sprocket, timing belt etc. originally set at #1 TDC. thanks...confused!
ah no, but you can be the first and tell us. hahahahahahah
ok on the 8v
if you have leaking seals then you really have no choice.
if they are not leaking dont change them.
it is tricky and you above ,tells me you may muff that.
sorry.
top and front covers off.
sorry
motor to tdc #4 , firing , all valves closed (justlook and fell loose lash on #4).
now mark all , timing marks and note if correct now.
now loosen all valve adjusters, (the 8v has bias on #4 and #4 so must be loosened, sorry)
timing belt swap
who am i to tell you what is best for you.?
some folks (sadly) just cut off the new belt and pound on the new belt with a rubber mallet.
taking noting loose save the covers.
what ever floats your boat. LOL.
setting the Cam with #1 means you have to align the top cam cog
to a NON EXISTENT bottom mark.
or , remarking the cam cog itself.
do not forget to mark all timing marks and key ways postions onall cogs.
the top cam cog has false marks. so becare full
the last step
crank bottom pointer aligned with top mark on pump. and key up.
on the cam/;
titty, dimple or E mark pointed UP. my 91 has dimple and machine mark.
Cam key DOWN !!!
if you are smart , you will pay careful attention to getting the tension perfect. if you do that , it may run 60 to90k more miles.
cheers
Old 07-01-2009, 05:59 AM   #3 (permalink)
Thanks for your input jtgh....I'll give it my best shot and treat it with kid gloves.
Old 07-01-2009, 01:35 PM   #4 (permalink)
no free lunch.
unless you want to see the youtube video of the
TBELT WACKER AND POUNDER MAN.
there is a way to do it. the shop crooks use.
cut belt off ,pound it on
then charge FLATRATE !
crooks born every day.
