ECT 2180 ohms is about 73deg F, (in the range) sound right?
dont know if this is overnight test or after a 3 hour cool off or?
best is to ohm them before first start in AM. both IAT an ECT and both will read the same because they equalized over night.
a really good test. then tell me ambient temp. at that moment.
Frankenkick issues:
this car has a SAMMI fuel pump, or?
car most not have a high powered pump ,it must push a value for the KICK
FPREG.
someone puts in a HD pump ,the little tiny FPreg will be overwhelmed.
The fuel pressure must be tested. anytime car is rich.
it is easy, just go to harbor freight and snatch up the $17 kit.
all auto stores rent them for like $5, (worth salt)
ISC when it clicks blow thru the air tube(top) and feel it open then close.
its just an air valve, (pistion, coil, piston, and seat)
DP:
at key on, the ECU leaves the Dash pot extened and car has extra air for starting.
then it start, then the ecu counts potatoes for number of seconds based on
ECT readings. if hot day the seconds are 3 . if North pole , way longer , 30 seconds or more.
yes the ECU controls the dash pot with its very own VSV.
here.
http://www.kick-fix.com/sensors/8v-sensors.JPG
part ID . 11
Pressure. ?
you are missing the stock fuel filter , which has the test port on the side banjo fitting.
you messed up. now you can test pressure.
no fuel rail in a TBI.
sorry, the iac looks like this.
and opens up , proportional to the water temperature.
IAC-thermo testing
this is off my Racing page ( extreme idle speed, = racing)
see the IAC actual , lid off. it rarely fails but must be working.
ignore lower photo. its 16v IAC.
if have spares so dont worry about buying one if bad. free.
this is a wax pellet driven device, wax expands radically with temperature.
just like the cars thermostat but this is for air.
this is device is what makes the car slowly lower its IDLE when cold.
