its flooding.
1; no hyper fuel pressure
2: no leaking injector TBI oil 0 rings.
2a: the 3 seconds is for fuel pump, then shortly, a very fast priming pump.
if you see fuel flowing key on , injector is bad, or O-rings cracked or shrunk from age.
3: ECT reading 10,000 ohms all the time. or some value that is not open circuit (as that would trip DTC for this. ) 10k is like Klondyke viles. North pool and rich as a piggy.
if egr is closed, its ok for now.
forgive me if i ask you to check something already tested. just ignore it.
you can appy 12vdc to the ISC and toggle it. good test.
even look at it. I have a video of it being tested.
Index of /sensors/tests/videos
pick one , wmv loads faster
play any tune you want , hahahah
ok just be clean, and snappy. on the ISC.
next:
on this motor , it is manditory that the DASH pot be open (pushing throttle open)
as you start the motor, (this air is critical or motor will flood , instantly)
there are the floowing sources of air.
IAC base of TB (open below 150f)
ISC electric,
DASHPOT for 3 to 30 seconds, (3 sec, in summer is typical)
and the throttel stop. (must never be moved ,have spec if some one did.
and last the idle bleed screw.
PS, flooding can be too much fuel or too little air at start.
