Old 06-26-2009, 12:40 AM   #1 (permalink)
joebama is on a distinguished road
Unhappy explaine more
i own a 1998 suzuki sidekicksport.the problem that i have is when i turn on the a/c it only work on the last two speed.someone did give me some advice but it's kind unclear.i pulled out the that black small box witch locate near the blower behind the glove box i swap it out with another i still have the same problem.the second problem that i'm having is that i have no power going on my master window switch.the third question is i feel a vibration when ever the car decelerate i had it look at i was told that there's was a play on the drive shaft so i wonder is this a common problem for this type of vehicle
joebama is offline   Reply With Quote
Old 06-26-2009, 01:38 PM   #2 (permalink)
the ac only kicks in , if power goes to fan
if resistor block opens UP, on any speed , the fan dies.
when fan dies for any reason , AC clutch is diabled. (AC amp functional logic)
whY:
easY. why ice up the evaporator ? now its plugged in ice , short order and no air at all.
IMHO.
yes, common with all cars with single speed motor.
or cars with out 3 phase AC , motors (100% electronic motors) called Variable frequency drive motors in the commercial sector.
ours is the Jules Vern type. ( i love em)
Battery >>> resistor >>>>> motor.
pick a resistor. with switch.
common fail.
the resistor runs hot, and has a finite life.
could be worse, the variable freq. controller bad for $1000
Old 06-26-2009, 02:42 PM   #3 (permalink)
Default more help
in the nutshell is that i have to change the resistors but what the resistor look like or can i replace it with a use one.what about the power i'm not getting in the master window switch how do i solve that problem.and about the vibration that is comming from the drive because of the play can i replace it with 2door side kick drive since mine is a 4doors vehicle.thank's for all your help.
Old 06-26-2009, 10:05 PM   #4 (permalink)
you posted 3 questions, bzzzzzzzz,
this is illegal here, and you will be punished,,,,,,,,,,,, heheheheheh
resistor,?
ok, buy a newone at suzuki or gm. or a used one at a wrecker. or beg here.
begging requires ,groveling and whining. hahahahahahah or nada.
you need drawings for window sw. 98 4d 1.8L sport ? with ac.
next
vibration from what? say exactly what.
drive what drive.?
we can send full drawings.
have meter?
Old 06-26-2009, 10:08 PM   #5 (permalink)
this is a resistor block
it uses the air box to keep it from overheating.
a cute trick really.
same place on 98 sport, just looked.
Old 07-01-2009, 02:27 AM   #6 (permalink)
Default another question
my sidekick has a vibration.my problem is i can't figure it out if it's coming from the front tire or somewhere else.the vibration always kick's in when the vehicle start to decelarate.t's driving me crazy but is there bearing in the front tire that may cause this.
Old 07-01-2009, 12:58 PM   #7 (permalink)
you going to throw vibration analysis on top of A/C
ouch. IMHO. grin......
start a post. please.
the front of the FSM has a Huge section called vibration analysis.
it is very difficult to do .
It could be lots of things.
try 2wd, try 4wd, try all gears. try coasting fast or slow, try inspecting the bearings up front like the maintenance chart shows. 15k inspection period. (little grease)
