Old 06-25-2009, 12:12 AM   #1 (permalink)
Badgerfan3121's Avatar
Badgerfan3121 is on a distinguished road
Default Need More power for 1.6L 8v geo tracker
hay, i have an automatic 4x4 1.6l 8valve 91' geo tracker, i was woundering what else i could do to get more power out of it. I have put a k&N air system on, i was thinking of a header but i wanted as much tourqe/power as i could get. any ideas. Thanks
91' geo tracker 4/4 automatic, new paint job, 16 speakers a rockford 15", flip up LCD touch screen jensen monitor, brush guard, led lighted interior, tinted windows, k&n air intake system, k&n oil filter, , 2" coil spring spacers, 5 1/2'' body lift, shift kit, 2" wheel spacers, cragar black soft 8" rims , bf goodrich tires 235/75/15, custom rock sliders, soon light bar, hood scoops, and 3 inch suspension lift.
Badgerfan3121 is offline   Reply With Quote
Old 06-25-2009, 02:52 AM   #2 (permalink)
Calmini sells a midrange cam and a header / full exhaust system. I think stock its only 80hp -so if you drop $1000 on mods you just might get to 100.
MarkB.NV
1991 Tracker, 8valve 1.6L, 5 spd, 4x4, 2 door, soft-top, 103,xxx miles, w/ 2 in suspension 2 in body lift, 30x9.5/15 MT tires.
Old 06-25-2009, 09:39 AM   #3 (permalink)
grc1 is on a distinguished road
What MarkB.NV says is so very true. Your motor is just about maxed out right from the factory and to get that little bit more is going to cost you lots of cash. There are the more common things to do such as ,cam ,exust,air breather,ect.
But if you want real HP you need to start with the enternals of the engine. The trouble is that the motor constuction will simply not alow it. And remain reliable. Sorrry but thats just the way it is.
grc1 is offline   Reply With Quote
Old 06-25-2009, 11:59 AM   #4 (permalink)
Oh ya, thats the other thing i was gona get. But, i was going to try to do somthin else if i could. Before i went ripin apart my motor. but if im gona do that, i was thinkin a engine re-build kit too. and bore it out. idk any other ideas like a throtel body spacer if they sell them, or a chip but i cant find any of them. Thanks
Old 06-25-2009, 01:04 PM   #5 (permalink)
Default snake oil city.
throttle spacer does nothing ( ecu learns it in 5 minutes and zippo) have dyno plots. and many to prove that. see my snake oil page.
chip.
if you can tell me what a CHIP is , ( please do) Fleebay, wow.
notice the brilliant obfuscation there ( amorphous , nebular)
Marketing BS , all.
The trick is to fool the ecu.
tell me what why and how, do you wish to fool the ecu? ( can be spotty)
This is called piggybacking (chip is BS) what do you wish to fool.
You first need to know the ECU is programmed to run in CLosed loop
full time (not W.0.T)
this runs 14.7:1 AFR.
to get cheap power, some ppl force the ECU out of closed loop.
If your motor is tuned and the senors are not bad, you can do this by pulling the O2 sensor.
some ECU's will go to the intrinsic AFR which is 12.5:1.
its illegal but out of the factory it was tuned to do that.
this will give you maybe 5HP.
want more power (8v is low) get the 1.8L and drop it in. 2.0L 2001+ is better.
or
a Grand Vitara V6.
The 8v cant breath and that is why they have the 16v.
the old ECU 91 , can get real upset with bad sensor inputs (piggy backs)
it gets upset and then punishes you with FailSafe mode.
Rich and retarded timing
so fooling it can be like throwing dice.
snake eyes.
Tuning a car without tuning the ECU, is mostly a waste of time.
but you can trim it a little.
Just like in the old carb days, tuning the motor with out rejetting is a waste of time.
same rules, diff, hardware.
or just buy a 4.0L or bigger jeep.
the jeep has more power , out of the box. and lots of potential.
Old 06-27-2009, 10:56 PM   #6 (permalink)
maximus_pr is on a distinguished road
or swap in a chevrolet v6 4.3 engine or a v8 there is a place in Tampa Florida that sells you the basic kit or even do the whole swap for you including crate engines ,if i'm not wrong the latest 4.3 v6 comes from the factory with 200hp and 270lbs torque more than enough power for all your needs ,i personally would opt for the advance kit no engine find yourself the engine there should be like zillions of them in auto salvage places and do the swap
here is a link to the place that do and sell the swaps here
maximus_pr is offline   Reply With Quote
Old 06-28-2009, 02:26 AM   #7 (permalink)
and snap all driveline parts 1 by one.
way too much torque on most of those.
but when young this is fun. breaking things.
seen one with the rear ring gear bent almost perfect arch. cute, for den room.
Old 06-28-2009, 10:00 AM   #8 (permalink)
i think you change everything transmission,drive shaft,transfer,and if i'm not wrong differentials too but again not sure about differentials
Old 06-28-2009, 12:21 PM   #9 (permalink)
Ole-Boy's Avatar
Ole-Boy is on a distinguished road
Better off to buy a Jeep if you want bad a$$ power.
Ole-Boy is offline   Reply With Quote
Old 06-28-2009, 02:35 PM   #10 (permalink)
There is one way to get a bit more power and that is a VW diesel kit.
Other than that I would suggest a power train swap , frame and all. You cut and quarter an exesting 4x4 and drop your tracker body on it. Probably the cheapest way to go.
