Old 06-23-2009, 05:02 AM   #1 (permalink)
oh4mud is on a distinguished road
Smile losing water forced out of over flow
i have a 1991 1600 16valve suzuki escudo water is forcing its way out the over flow also the idler wasn't getting any water to it but is now i have done
head newgasket
new radiator
new thermostat
going to pull out waterpump is there anything else i should be looking at?
any help would be great thanks
oh4mud is offline   Reply With Quote
Old 06-23-2009, 07:38 AM   #2 (permalink)
Rhinoman's Avatar
Sounds like an airlock. Remove the radiator cap and run it until you see the thermostat open, the coolant level will probably drop also. That is usually enough to fix it.
Old 06-23-2009, 08:53 AM   #3 (permalink)
tusong200's Avatar
Gallery: 3
tusong200 is on a distinguished road
Pin-hole leak in head, Seen it happen in motorcycles. Just another possibility......
92 4dr 16v A/T 4wd (The Creature)
81 VW diesel Pickup
tusong200 is offline   Reply With Quote
Old 06-23-2009, 04:13 PM   #4 (permalink)
ok but a silly question how can you tell if thermostat open ?
Old 06-23-2009, 04:15 PM   #5 (permalink)
had a full test done on head pressure test etc came up all good
Old 06-23-2009, 04:17 PM   #6 (permalink)
obradleyo is on a distinguished road
why didn't you change your water pump when you did the head gasket!!!!.... Also did you get the head checked by a professional so see if it wan't damaged....
1995 Kicker 5 speed, 4 dr, 4wd, Ac,Ps 16v 31" TSL's,Calmini 3+3, torquer cam, magna flow with 2" tail pipe, calmini steering stablizer....... Sacramento,ca
obradleyo is offline   Reply With Quote
Old 06-23-2009, 05:09 PM   #7 (permalink)
yes it was checked buy a professional head specialist and the guy i brought it of said it just had a new head put on it and the water pump look like new i will take pump of today
Old 06-23-2009, 06:36 PM   #8 (permalink)
Rhinoman's Avatar
You'll see when the thermostat opens because the coolant will start rushing round the top of the radiator.
Old 06-23-2009, 09:43 PM   #9 (permalink)
riley is on a distinguished road
Make sure your rad cap is good. They do wear out.
riley is online now   Reply With Quote
Old 06-24-2009, 09:18 AM   #10 (permalink)
grc1 is on a distinguished road
How to test thermostat.
Take out old thermo and place in very hot (near or at boiling) water. Look for movment such as opening and closing of center metal diafram.If parts are opening in hot water and closeing in cool or warm water then thermostat is good. If no or very litle movment, then tremo is nfg and must be replaced. This test should always be done on all new thermos before you install. In past I have bought a new thermo and it was found bad right out of the box.
grc1 is offline   Reply With Quote
