The biggest you can mount is... 235's last I knew. 30's will fit with a little rubbing on 4x4, I don't think they would fit a 2wd model as easily, not sure!
I would think that 9 1/2" wide is too wide to fit properly on the 5 1/2" wide stock rims. They'll fit but they will be very 'crowned' and you'll wear the tread out on the center of the tires very quickly. Also not very good handling/steering. For those tires to fit properly you need wider rims.
I've been running that size for two years on the stock rims, first with no lift then one inch body and one inch spring spacers, very minor rubbing on the frame, I adjusted the steering stop to clear, hardly noticed the change in steering lock.
