now the bad grounds and main fuse panel (right finder front) that will cause alternator and all power to car to die , intermitantly.
common-failures
my bad grounds page above.
and bad main fuse link box . (water and salt can go up strut tower, sadly) hitting this.
all these fails are very common on all sidekicks.
so far we know
1992 Sidekick 4door 4wd auto 16v
we dont know country. ( 53 connotes Calif. but some times canadans try to use them)
we dont know if this car is FED or Calif car. if in N.Americas.
the FSM says, bad power, bad ECU, wrong ECU, bad Calif ID pin . for 53.
or bad ROM , rom is reading wrong. ( bad power supply inside ECU )
this code shows in 89 to 95 cars only and in their respective FSM.
it can also mean the ECU got lost.
this can happen when ecu is trying to make spark or injections, and power is disturbed.
it quite naturally goes lost. and reboots.
that is all i know on 53 and it is not a fun problem to have.
Im glad you have it not me. hahahahah .
no , i will help you find it....
