Old 06-10-2009, 08:17 PM   #1 (permalink)
Prokopec is on a distinguished road
Default Signal Lights
Hello,
My signal lights stopped working, both ext on the dash.
please help me to find out why this is.
Prokopec is offline   Reply With Quote
Old 06-10-2009, 08:27 PM   #2 (permalink)
year, body 2door ? 4door.
just a little hint, what do you drive.
Old 06-10-2009, 10:17 PM   #3 (permalink)
vonroretz's Avatar
vonroretz is on a distinguished road
its that new 50v 6.0 2 dor supercharged
Now
New Chrome Grille
Sliverstar Headlights
Bajha Fog lights
Kc Daylighters
All Desert camo interior
6 Speakers
2 12"inch Kicker comps Subs
1 1000 watt Mtx amp
Custom slim box to fit in the back
Sony Deck
Xm Radio
Tom Tom Navagation
Custom Intake and Cone Filter
K&N Oil filter
1.5inch coil spacers lift
Rock Crawlers(crome)Cragers
New 30 inch tires
vonroretz is offline   Reply With Quote
Old 06-10-2009, 10:40 PM   #4 (permalink)
94 ? (wild guess based on the the popularity of year 92-95)
check stop haz fuse above left knee.
if good, replace hazard relay.
if you want to prove it, you need a meter.
Old 06-11-2009, 01:24 AM   #5 (permalink)
tell car, get schematic, imagine. it.
Old 06-11-2009, 05:46 PM   #6 (permalink)
Default Lights
I have a 92 Sidekick, 2rd. ive checked the fuses and the bulbs are good.
Old 06-11-2009, 07:31 PM   #7 (permalink)
Test 1:
you did check the turn lamp bulbs im sure...
but they cant all be burned out , right?
test 1a: cycle the hazard switch 3 times to be sure it is not stuck half way.
it is a simple system but on cars, it can be a bad module or bad wires.
replacing all the modules will cost about $300 or more.
we could diagnose it ,
or
we could replace each module 1 at a time and pray we fix it.
starting from the cheapest (bulbs) then the id 41 flasher. and then the combo switch.
for many they are now broke and its not fixed.
sometimes its just the trailer wiring shorted.
if iI didn't have a meter , then this is how id proceed,
id use the hot wire technique.
one must make up a jumper wire with an inline 20amp fues. (or 15amp)
keep this ready for tests. (FSM recommendation)
step 2
pull the flasher relay module #41 from dash and unplug it.
see schematic.
see the flasher?
see the pins. now jump pins
see attachments.
schematic
and
loc dwg.
now the test 2 , procedure.
with a paper clip (unwound) jumper the flasher relay pin yel/white (12v is here)
and the green wire , not the flasher itself the socket it came out of.
now
turn ignition to on ,not accessories, but on ,see dash lamps glow.
ok ,you now have power to the turn flasher pin yel/wht.
you could voltmeter this node or use a test light to validate this.?
with the jump placed and key ON.
we can not throw the blinker to Left and then right and the lamps will
glow brightly and not flash,
this tests the path from end to end.
if this passes and the turn fuse dont blow then the flasher is in fact bad.
but making sure there is 12vdc on the yel/white wire , assures you that that the flasher has power.
if by chance this 12v is missing ,then the hazard switch is bad or the combo
directional switch is bad.
you now have all you need to fix this problem.
Old 07-01-2009, 04:23 AM   #8 (permalink)
onestoptakeaway's Avatar
onestoptakeaway is on a distinguished road
step 2
Hi,
Usually if the signal lights up and not flashing than quite likely the flasher relay module is Bad right? May I know which part of the dash can I find it?
onestoptakeaway is offline   Reply With Quote
Old 07-01-2009, 01:20 PM   #9 (permalink)
Default ext. lighting , roard map. all you need is this and meter.
ok 92 , 2dr, would have been nice the motor too. but....
check fuses first as always.
first wiggle crap out of emergancy flasher buttong, (infamous for sticking 1/2 way)
the problem can be grounded out SIGNAL WIRING in BODY. {trailer hack?}
if that is the case (and is most common) then it burns up combo or worse.
make sure signal fuse is NOT OVERFUSED. put in the correct fuse.
i unplug the combo and hot wire the left and right.
then if my hot wire fuse blows, i measure the current with an ampmeter.
doing that saves buying all the parts 2 times.
and #3 DVM can do this magic trick.
as promised.
schematic. (92-95 accurate i think)
see green/red and green/yellow.
pull the combo plug and hot wire these and test the actual load first.
1: do lights work now.
2: do i blow a fues when i hot wire it( shorted trailer wiring?)
3: do the work and draw less than 10 amps total.
trailer conn. is behind left rear tail light. look for mangled wires there first.
the turn sig. flasher gets power on the yell/white wire.
if not check fuse.
if still not , bad combo.
the flasher has a relay or transistor inside? that gates power to the flash circuit , independent of load (hopefully)
so if you can only get it to flash buy hot wiring its output (unplugged )
then it is bad.
, motto, save that combo from burn up.
