Hello all,
I own a 1991 Geo Tracker Softop, 8v, 3L30 Automatic transmission 4WD and it is a USA car with 92,000 miles on it.
I have many issues with my Tracker, the most pressing though is a slipping transmission. The fluid smells good and is red, it used to leak out of a bad modulator (which I replaced). Than for a while things were great, but recently it started slipping only when cold, and today it started doing this most everywhere in the low gear.
I guess I am wondering my options, there is a possibility that I have a leak somewhere, if that is the case than my fix would be easier and cost less right?
Otherwise it sounds like a new or repaired transmission is the way to go?
The second most pressing situation is the fact that it leaks oil pretty steadily, the owner before me over filled the oil and I am sure blew out some seals, I replaced the head gasket already but it looks like the oil pan gasket needs some attention. How hard will it be to replace that seal along with the main seal
both of which need replacing from what I am told.
Last but not least my softtop corner pieces (forgive the stupid language) are broken, what are they called and where can I find them?
Otherwise I really like the vehicle
