Old 06-10-2009, 10:19 AM   #1 (permalink)
Iwanna4x4 is on a distinguished road
Default My New 95 Tracker
Just picked up my new toy yesterday it's a 2 door soft top 95 geo tracker 16 valve. I took it straight from the guys place to get some new 235/75r15 mud terrains put on it. It looks sweet soon to come is a 2 inch lift. I'll get some pics posted soon
Give me some tips to keep her running good on and off road!
Iwanna4x4 is offline   Reply With Quote
Old 06-10-2009, 01:13 PM   #2 (permalink)
onestoptakeaway's Avatar
onestoptakeaway is on a distinguished road
Wow ! 235/75R15 sweet.... so have you tried doing full turn left and right to see if the wheels touches any part of the car? It seems like your new tire circumference comes up to 6.54% bigger than the default 205/75R15 so if your speedometer says 70mph, your actual speed will be 74.58mph.
onestoptakeaway is offline   Reply With Quote
Old 06-10-2009, 02:26 PM   #3 (permalink)
rns0504 is on a distinguished road
Not entirely true. The speedo with 205s reads faster than actual by a few percent. 235's put it dead accurate.
rns0504 is online now   Reply With Quote
Old 06-10-2009, 05:50 PM   #4 (permalink)
YES the wheels turn from lock to lock with no rubbing at all, but they are also on an 8 inch wide rim, and the speedo seems to be fairly close.
Old 06-10-2009, 10:56 PM   #5 (permalink)
but mine are 75 actual for 70 indicated. 235's same.
stock tranny speedo gear sets. ( 5 permutations one has)
same as the math. fyi
see my last table for gear corrections on speedo
unsafe-at-any-speed?
them the choices.
Old 06-10-2009, 11:27 PM   #6 (permalink)
Milwaukee is on a distinguished road
Please tell us what mpg you been get with that tires?
I get 28.5 mpg with 205/75/15
94 Geo Tracker 4wd 5 speed manual 2 doors.
96,200 miles and I get 27 mpg all times BEST mpg was 31.5 by stay 55-60 mph on highway
Milwaukee is offline   Reply With Quote
Old 06-11-2009, 01:26 AM   #7 (permalink)
get 30 plus ( im still tuning it)
2door 16v.
stock tires on 96 , really sips fuel.
Old 06-11-2009, 01:36 AM   #8 (permalink)
2door 16v.
You get 30 mpg is that with cruise control? My geo Hate me try steady speed it seem it continued adjust gas pedal to stay speed then my foot fall sleep or pain.
Hey you plan replace timing belt on that geo?
Old 06-11-2009, 03:10 AM   #9 (permalink)
So you got fancy rims too BTW what is the max for stock rims ? Is it 225/70R15 or 235/75R15 ?
Old 06-11-2009, 02:48 PM   #10 (permalink)
no cruise yet, installing generic soon. JCW.
just driving on country roads 45mph.90%
long distance long run at 60 , can net way more. many post this here , profess that.
and that is US Gallons not Imperial (long gallons)
the 16v motor is very efficient as is the MPI brain.
and yes, some speedos do read high or too low, depends on age and luck.
the speedo is at best 5% accurate. or worse.
and yes, many mfg purposely set it 3 mph high to keep you honest ,
just like the gas gauge, it will be offset. (or worse "GAS" non linear"
and the speedo is non linear.
it is accurate only in its sweet spot, too low or too high it gets very inacurate readings.
it is a very crude magnetic coupled device and that is ITS nature.
the benefit is it is DIRT CHEAP to make.
i think every issue ever of road and track explains that , as it seems.
many speedos are set to 55,and then later to 65 sweet spot , (remember Richard Nixon )
ahahahahah ,, double nickels , tricky dick.
but you can tune and calibrate it your self. if motivated.
i worked as instrument tech and calib. tech in USN for years.
(was drafted to army so ran to USN, lifes a beach)
hope that helps to understand the lil beast.
