Old 06-07-2009, 08:56 PM   #1 (permalink)
Milwaukee is on a distinguished road
Default WOuld this cruise control work? Found for $94
Well for some reason my Aunt call me if I could install cruise control on her chevy Astro van
so I check website where she order. Couldn't believe $94 Audiovox Electronic Dash-mount Cruise Control : JC Whitney: Auto Parts & Accessories
Question would that work with my 94 geo tracker and 97 suziki X90?
I want cruise control so I could get good mpg but it so hard to keep 60 mph with foot vary position to keep 60 mph.
My Uncle want too so I need know if it will work with geo tracker.
Milwaukee is offline   Reply With Quote
Old 06-07-2009, 10:09 PM   #2 (permalink)
check out the vendor , actual maker of the unit , not JCW.
they have a web page. (google it ,easy)
they will tell you what you need.
it will mechanically connect to the throttle. , brack lamps, power. and will need a RPM attachment.
some have a clamp (better ones ) that clamp to the drive shaft.
you add a magnet ring to drive shaft and a sensor is places near.
this is done on rear boss of 4wd box.
this becomes VSS.
the 2 hard parts are throttle connection and VSS.
vss = vehicle speed sensor.
the throttle deal must be done with care,as you wouldnt want the throttle to jam.
Old 06-07-2009, 10:43 PM   #3 (permalink)
ok
but I think my 94 geo don't have vss it have cable that mount to transfer case for odermeter.
Do 97 suzuiki X90 have VSS?
I work on cruise control before on F350.
Old 06-07-2009, 10:53 PM   #4 (permalink)
Ok I check
I say it could work but I need check what throttle cable look like on geo first so i can figure if it could work then I let you know how it will.
I say I would order next week or unknown.
Old 06-08-2009, 12:11 AM   #5 (permalink)
id say the throttle bell crank adaption is key
Old 06-08-2009, 12:38 AM   #6 (permalink)
What about 8V ? Are they same throttle cable like this pic?
Old 06-08-2009, 01:42 AM   #7 (permalink)
vonroretz's Avatar
vonroretz is on a distinguished road
its smlilar but on the back side where the cap and rotor is
Now
New Chrome Grille
Sliverstar Headlights
Bajha Fog lights
Kc Daylighters
All Desert camo interior
6 Speakers
2 12"inch Kicker comps Subs
1 1000 watt Mtx amp
Custom slim box to fit in the back
Sony Deck
Xm Radio
Tom Tom Navagation
Custom Intake and Cone Filter
K&N Oil filter
1.5inch coil spacers lift
Rock Crawlers(crome)Cragers
New 30 inch tires
vonroretz is offline   Reply With Quote
Old 06-08-2009, 02:06 PM   #8 (permalink)
no , the 16v has side draft TB
the 8v has down draft TB.
same but diff.
same butterfly, shaft and bell crank.
just positioned , diff. nothing more.
here 8v
Old 06-08-2009, 05:23 PM   #9 (permalink)
ecoast's Avatar
ecoast is on a distinguished road
Default OP...
In the past Audiovox was made by Dana corp, who also was building OE...
If you can find a vss and a tach signal, brake switch, constant 12v, switched, etc. you will have no problem.
If you search, you may find a stalk to replace your factory; it's only 4 wires o control.
They come w/ hardware and brackets of several types to attach to linkage.
Works supisingly well; I've had factory cruises that did not work as well.
I had an aftermarket company and we put these in @ new car dealers 20 years til they all started coming w/it.
ecoast is offline   Reply With Quote
Old 06-08-2009, 09:34 PM   #10 (permalink)
Welcome to Audiovox
excellant comments.
thanks for dana hint.
check out manual. shows many views of many ways to do the mech. throttle part.
super good examples.
wow
