Which wheels interchange with a 1990-98 tracker. I want to put wide knobbie tires on mine but want to know which rims can I look for in the junk yard that will fit.
older jeep and ford van rims work, i have a set ov ford van 10" wide ones on mine. where r u located?
__________________ Now
New Chrome Grille
Sliverstar Headlights
Bajha Fog lights
Kc Daylighters
All Desert camo interior
6 Speakers
2 12"inch Kicker comps Subs
1 1000 watt Mtx amp
Custom slim box to fit in the back
Sony Deck
Xm Radio
Tom Tom Navagation
Custom Intake and Cone Filter
K&N Oil filter
1.5inch coil spacers lift
Rock Crawlers(crome)Cragers
New 30 inch tires
I wasn't aware that any Chevy wheels would work, but some Dodge wheels will, as they are usually interchangeable with Ford. I think that you will be looking for truck wheels instead of car wheels. Someone can confirm, or deny that.
It seems that someone had a link to a chart here once.
__________________ GaryS
'95 (US, made in Canada) soft top Sidekick JX, 4x4, 1.6L 16 valve, 5 speed, Superwinch hubs- stock except for tow bar
I am looking for plain wagon wheels all steel about 7-8 inch. PLain jane wagon wheels... where may I find those in the junk yard? What brands of automobiles would have those that would fit my tracker?
Thank you
I'm not sure what you mean by "wagon wheels", but like we have said, any 15" wheels that fit a Ford, or Dodge 1/2 ton truck (van or pickup) and possibly some cars should fit. Ask at the wrecking yard, or tire store that sells used wheels. 5x5.5 is the bolt pattern.
Also I almost forgot, I think Kia Sportage uses the same size wheel and bolt pattern too.
Hope this helps!
AMC - Jeep (5 bolt) '42-'89
Chrysler - 8 cyl. & wagon '46-'55- Imperial '54-'66
Ford 1/2 ton van
Ford Bronco, F100
Ford - all '28-'48- full size P.U., van, Bronco '49-'89
International Scout, Travelall
Lincoln - all '52-'60
Mercury - all '39-'51
Suzuki - Samurai '86-'89
Jeep CJ 1955-1986
Chrysler Imperial ‘54-’66
Ford Bronco F100
International Scout
Suzuki Samurai ‘86-’89
Suzuki Jimny
Suzuki Vitara / Sidekick / Tracker
Suzuki X90
Eljot
dont forget the 4.5 or 4.75 inch center opening, because a dodge ram 1500 rim fit the truck bolt pattern but wont clear the hubs!!! un less its 2wd
