Old 06-03-2009, 09:56 PM   #1 (permalink)
Kaoseighty9's Avatar
Kaoseighty9 is on a distinguished road
Lightbulb Alternator Question
i searched up the converter for amp's to watt's
and I'm pretty sure i have a 70 or 75 Ohm's alternator
but what I'm getting as a result is
P = I 2 x R ?? this right?
power = amps(squared) x resistors
if so that's like
2940 = 70² x 0.6 <-- I'm pretty sure it has 0.6 not 100%
if some one could correct me in any way please do
this is what i researched and i don't get electricity very
well.
1998 Zuki Sidekick Sport 4-Wd 5-Spd Manual
2-3/4" lift home made
235/70R16 Goodyear tires
215/85R16 FireStone Destination M/t Ordered!!
Sand Blasted OEM Rims Sprayed Black
( 4 ) Kc 130 Watt 6" Lights (Roof)
( 2 ) Kc 100 Watt 6" Lights (F. Bumper)
)(* War Isn't About Who's Right, It's About Who's Left ! *)(
Kaoseighty9 is offline   Reply With Quote
Old 06-03-2009, 10:21 PM   #2 (permalink)
converters , or inverters?
ahhh, conversion equations.
Power (dc) = I x A. or I squared x R.
alternators are rated in amps. ( volts is a give right. 12.5 to 14.7)
if you have a 70 amp alternator , it can output 14.7v x 70a = 1029 watts ( or 1k watts.)
it varies by RPM and the alternator mfg has charts to demonstrate the performance.
are you trying to do an energy budget , just ask how to do.
add up all the loads , in amps.
that is what you need.
at a little more for hot days.
Old 06-03-2009, 10:46 PM   #3 (permalink)
okay thnx because if thats to im at like dead end line
because i have i think lights are like 830watt's? + 300watt amp?
thats pushing it al together haha
Old 06-03-2009, 11:11 PM   #4 (permalink)
no problem.
you have 4 x130 plus 2 x 100 . so that that's 520 w + 200 or 720 watts added.
divide that by 14v get 51 amps. you need ,
FSM says stock alt. is 55 amps.
so you have maybe half remaining on the stock. ( shooting from hip)
you have 25(factory) amps to play with , you need 51 to run lights.
so you need 25 amps extra over stock.
i round your lights down to 50. ( so you need 25 more amps)
55 stock+25 need = 80amps. so you at least need a 80amp alternator. total.
dont forget stock, has lots of overhead capacity but cant do 51 amp extra.
if you have huge power audio amp that can play in.
Old 06-04-2009, 12:47 AM   #5 (permalink)
no clue but thats what i have installed this minute and for the past say month
and they both work together but i read up that stock 98 kick sport has 70 is that wrong?
Old 06-04-2009, 02:28 PM   #6 (permalink)
varies by country ,and year. ( i quoted FSM from USA E03 market KICK)
i cant search all 93 markets to find max amps. all kicks. no can do.
only way to find reality is pull alternator get OEM name and part number.?
Mitsubishi? then p/n , then look it up at Mitsu. dot com. (catalogs)
someone could have changed it out.
Old 06-04-2009, 02:34 PM   #7 (permalink)
okay well thnx i know a friend take his alternator to a shop close to where i work and
they re build it so its stronger im going to have to do that or add another battery if i want a 10K winch ahha well thnx for your help
Old 06-04-2009, 02:56 PM   #8 (permalink)
that's correct any good electric shop can up the alternator amps.
most.
unless , maxed out now.
winch, another power eating monster.
Old 06-04-2009, 04:54 PM   #9 (permalink)
vonroretz's Avatar
vonroretz is on a distinguished road
Just Buy A Deep Cycle Batt Big 3 Upgrade New Alt
Now
New Chrome Grille
Sliverstar Headlights
Bajha Fog lights
Kc Daylighters
All Desert camo interior
6 Speakers
2 12"inch Kicker comps Subs
1 1000 watt Mtx amp
Custom slim box to fit in the back
Sony Deck
Xm Radio
Tom Tom Navagation
Custom Intake and Cone Filter
K&N Oil filter
1.5inch coil spacers lift
Rock Crawlers(crome)Cragers
New 30 inch tires
vonroretz is offline   Reply With Quote
Old 06-04-2009, 05:01 PM   #10 (permalink)
deeznutts77's Avatar
Gallery: 4
get a chevy alt kit. it has the bracket to bolt up and you can get it with a 105 amp alt or get your own and put a 200 amp one in. i think there 45$ for the bracket and 120 for alt, separate.
To a life consumed by slow decay
