VIN Decoder - Suzuki Forums: Suzuki Forum Site
Old 05-25-2009, 11:18 PM   #1 (permalink)
idahojack is on a distinguished road
Default VIN Decoder
I found this VIN decoder Suzuki VIN Decoder @ Motoverse.com and ran my VIN through it and found out my little Frankenkick originally had a 3 speed auto tranny. So now I know the 5 speed in it was probably installed when they put the 16V engine in it, meaning it probably only has 95K miles on the tranny, same as the engine. That also means I probably have 4.625 difs, which explains why my speedo (when compared to a GPS unit) reads about 10% slow. This Frankenkick does present some challenges, I am in the process of ordering an OEM clutch cable from Southwest Suzuki. I was not sure which year cable to order, so I emailed my specs to them and Keith said he thinks the only difference is the length, so I should go with the 16V cable, it's longer. For now I don't have any questions, but if anything I typed doesn't look correct, please let me know. Thanks, I've learned alot from this forum, and Jerry's info links are amazing.
98 Tracker, 4dr, 1.6L 16 valve engine, Auto tranny,
4x4, AC, PW, PL, no lift, stock tires, 120K miles.
92 Tracker, 2 dr tin top, 1.6 8 valve engine, 5 speed, 4x4, AC, no lift, stock tires, 78K miles.
idahojack is offline   Reply With Quote Quick reply to this message
Old 05-26-2009, 05:10 PM   #2 (permalink)
deeznutts77's Avatar
Gallery: 4
it said mine is a 4 speed auto, its not and never been
96 jx 5 speed 1.6 16v "cold" air and try y header, underdrive crank, kawasaki zx6 muzzy muffler, gm alt kit.
96 "sport" 3spd auto 1.6 16v 2dr geo tracker all stock
It might not b fast but it looks it!!!!
deeznutts77 is offline   Reply With Quote Quick reply to this message
Old 05-26-2009, 05:45 PM   #3 (permalink)
Banned
Default diff, years diff rules for VIN.
above link if motor cycles ONLY. the 8th digit on some is motor type others its a body code.
only the FSM can help. (or enter the whole number to Carfacts)
here is 89 rules set
no tranny , sorry.
the first pages of all FSM show Vin decode.
and in newer years they have diff. codes for vin.
the online guys love to mix up facts ,
the assume 96 = 89 and no it does not.
if you need other oem decodes let me know.
Old 05-26-2009, 05:47 PM   #4 (permalink)
Banned
they also changed engine codes many times.
thru years.
it's a gotcha
Old 05-26-2009, 05:48 PM   #5 (permalink)
Banned
also, the engine sn has a letter.
like G16Lnnnnnn
the L = year. and follows the 10th digit year rule in VIN.
that, they dont mess with.
Old 05-26-2009, 07:49 PM   #6 (permalink)
Thanks for the info Jerry. Just have one question, where on the engine is the SN located? Thanks
Old 05-26-2009, 08:54 PM   #7 (permalink)
Banned
1.6L is here. other motors, v6 are diff.
Old 05-26-2009, 08:56 PM   #8 (permalink)
Banned
on the 16v it can be murder to read. the exh pipe is in the way.
clean it. and use light and mirror on 16v.
ahahaha , and learn to read backwards, ahahahaha
Old 03-08-2012, 01:30 AM   #9 (permalink)
redtrackerkid is on a distinguished road
Default BIG vin PROBLEM
hey guys i have a weird problem im second owner of a 1990 geo tracker lsi 4x4 i just tried running the vin code and after triple checking that the vin was right i ran it thru Free VIN Decoder - Vehicle Identification Number Report and it came back as a 1990 geo tracker 2WD.........i know for damn sure its a 4x4 has anyone ever have this problem before
redtrackerkid is offline   Reply With Quote Quick reply to this message
Security Question
