It definitrely should. as long as the stock head unit is considered "double din", yes. Im not familiar with the brand, but so many companies make touchscreens nowdays. All new head units should come with trim piecesthat you can adhere to the existing dash panel. and you can usually install a double din unit without having to use a dash install kit. all you need is the wiring harness. if you want to check for sure, the company that actually keeps up to date kits is scosche.com .
and if its one of those oddball units, break out the dremel tool and grind away. Let me know how it turns out
