Old 05-05-2009, 12:57 PM   #1 (permalink)
m9b7v5 is on a distinguished road
Default With a/c what controls the supplemental electric fan?
Continuing my series of newb questions ...
i removed the a/c from our new 500$ buggy/beater ...
noticed the second fan, electric, in front of the radiator ...
with my removal of the a/c system complete will the fan still come on at a predetermined engine temp or did it get it's signal from the a/c system?
if it's controlled by a thermostat switch i won't bother anything ...
if it's controlled by a/c system i'll wire a switch ...
thanks ...
Edit:
my sig shows up in user cp but not on this post ...
this question is in regards to a '95 tracker ...
m9b7v5 is offline   Reply With Quote
Old 05-06-2009, 10:43 AM   #2 (permalink)
The condenser fan is controlled by the AC system and has its own relay. If you removed the entire evaporator case from the vehicle, that should have eliminated system communication with that relay. Wire a switch to ground the relay at terminal 3 (blue/red wire) for fan control. If you left the connector intact when you removed the case, you should find this wire in a 10 wire connector already inside the vehicle which will make the connection to the relay from a switch fairly simple.
Old 05-06-2009, 10:46 AM   #3 (permalink)
thanks very much
'95 tracker,3spd,16v,4x
'85 bronco 60's sas/doubler ...etc
'01 cummins 505/1032 at the wheels
'06 cummins wifes caddy
i'm just the wife and kids mechanic
Old 05-06-2009, 12:52 PM   #4 (permalink)
air-conditioner-repair
any questions now.
de, road map.
Old 05-06-2009, 01:32 PM   #5 (permalink)
road map indeed ...
much thanks for the post and the info on your website
