purchased a '95 tracker to make a fun buggy ...
(309k miles new junkyard 16v 1.6 with approx 60k on motor, 3 speed auto)
was going to removing everything from the frame up and make a tube cage ...
But drove it home and it did very well ...
wife and i and two dogs loved it ...
pulled into the garage and the newly filled gas tank split at the seam
wife and i removed the intererior, bumpers, and rotted frame from the rear shock mounts back ...
but everything else was in suprisingly good shape ...
seats, dash, paint, tranny, axles all in pretty good shape
my delema is whether to...
1) break out the mig, fix the rear frame, buy a gas tank and make it a nice spare 4x4 ...
or
2) continue with the fun "grape ape" buggy plans we had in mind when we bought it ...
deciding factor may be exhaust and computer related ...
if i run it on the road everything will stay in place as it runs strong ...
powerbraking resulted in several 1 wheel 30' burnouts ...
as buggy i was going to remove everything exhaust / emmsions related and make the a/c compressor an air compressor ...
i want to keep it cheap either way ...
can i remove the ENTIRE egr system and stock exhaust (replaced with a short muffler) and expect the fuel injection function well for an offroad tube buggy that will only see 1k miles a year tops?
or is the suz computer too smart ...
i have a friend with a geo buggy that probably wieghs 1/3 less than stock, who removed his exhaust from the cat inlet back and welded on a small glasspack ...
but our new project is noticeably stronger stock than his 33 x12.50 'd buggy is ...
is it his larger tires or does the suz computer go into some kind of limp with everything removed?
have read some on here and his doesn't seem to run rich using the NASAL computer
but his has less pep ...
