hot wire the starter. if
THAT works the cab wiring (and tranny/clutch switch , or ign, switch is bad)
gee, i supplied a schematic , and an example of a live test.!
if the
hot wire test fails?
then the problem is:
starter or charge system. ( it must hot wire and crank briskly )
but how do you tell which.? is bad , charge or starter.
well , that is easy.
1: fresh battery installed, full charged out of other good car.
2: place a volt meter as my drawing shows.
3: crank , hear funny sounds now? from starter , good,, and read meter.
4: need 10v or more,. if 12v and not making a sound starter is bad (or solenoid)
just 5 steps,
move the red meter lead to big red lug, next. (meter ground is attached to engine block ground)
crank motor again. it must be 10v or more. (while solenoid is fully energized , hear it?)
or you have bad battery cables, or motor (starter motor) is shorted. (or hydralocked motor)
if you suspect bad battery cables then just place the VM across each and crank
the is called the cable voltage drop test.
if over 1/2 volt , expect to need new cables. (max drop 0.50 volts.)
meter placed at extreme ends of cables.
only rarely is the motor shorted. (but happened 1 time here , this forum)
this caused the solenoid to bounce back,
