Did you clean the port in the plenum as well as the tube? Port 1 as shown in last pic here:
EGR-repair-methods
From what I understand, the stall test can pass but the system can still be clogged enough to throw the code. Cleaning that port is crucial, both where the tube connects to it, & the inside. I was able to just take off the black throttle cover & loosen the 1st clamp on the intake tube & push the tube off to the front enough to get in there.
Also, did you reset the code? Or run the car at highway speed enough to let it reset itself? Might just need to drive it long enough that it runs (& passes) the test. hth
Fuzz
