Old 04-30-2009, 04:09 PM   #1 (permalink)
froggy is on a distinguished road
Default Tracker stuck in 4wd
I am looking at a Tracker to purchase. It is stuck in 4wd. I have a Samurai that the transfer case stuck in neutral. I had to replace the sheet bushing. Do the Trackers have the same setup as the Samurai's. If so, Will changing this bushing fix the problem on the tracker?
froggy is offline   Reply With Quote
Old 05-04-2009, 10:43 AM   #2 (permalink)
What is a sheet bushing?
Old 05-04-2009, 02:13 PM   #3 (permalink)
The sheet bushing is a plastic type washer that sits under the shifter. Over time, they will fall apart and allow the shifter to drop. This will cause the shifter to stick in position. It is a simple fix. The sheet bushing cost about $15 at a Suzuki Dealership.
Old 05-04-2009, 02:23 PM   #4 (permalink)
you did NOT say what year.
what sheet.
with the shifter out, you can shift it, manually, with a screw driver (large), if need Be.
replace all plastic parts 21?, put back , fixed.
Old 05-04-2009, 07:16 PM   #5 (permalink)
It is a 1991 2 door hard top?
Thanks for the diagram! The same as a Suzuki Samurai.
Old 05-04-2009, 08:41 PM   #6 (permalink)
GeoZilla is on a distinguished road
quite possibly the linkage is bent and wont disengauge the gear..
jsut a thought.
Being in the army is like being in the Boy Scouts, except that the Boy Scouts have adult supervision
12 Volt Fans & Heaters | 12V Portable TV's | 12 Volt Refridgerators & Freezers
GeoZilla is offline   Reply With Quote
Old 05-05-2009, 01:22 AM   #7 (permalink)
hope for easy fix.
pull it and make sure it indexes that tip of the shifter, and can not fall out , of index.
