Old 04-29-2009, 01:00 AM   #1 (permalink)
shackwrrr is on a distinguished road
Default Brake lines
I wanted to know what kind of brake lines do our rigs have? are they standard double flare or are they iso flare. I wanted to know because mine has no brakes and I need lines but Im about 200 miles away from it right now. They are 3/16ths line though?
1993 sidekick JLX 4dr
1.6-16v
5speed
USA
shackwrrr is offline   Reply With Quote
Old 05-02-2009, 08:55 PM   #2 (permalink)
get them from SW suzuki
for some reason zuk OEM lines are cheap. like $15 , not bad at all.
i dont know spec on them but there are others here that do.
i have a spare at home will look tomorrow.
can give OD and thread size and pitch.
and flare question.( im sure it is but want to refresh reality)
Old 05-04-2009, 01:10 AM   #3 (permalink)
ok shackwrr
post 10 is , 10mm x1p line fittings.
hope that helps you.
i have a list to look up for you tomorrow.
double flare ? lines and
code 53 in my fsm .
online resources net zero answers on 53, cept "bad ground" ECU think it is.
prev. topic:
http://www.suzuki-forums.com/suzuki-...e-pipes-2.html
never use pure copper "ACE or HomeDepot" lines. deathtrap that is.
there are many exotic alloys that are rated for 23k PSI. but will be more more expensive
then brand new Suz line. ( the f/r 4dr long line is $34 )
Old 05-04-2009, 01:09 PM   #4 (permalink)
brakes facts. (surely Metric)
od = 5mm
id="
fitting diameter. 10mm
fitting pitch = 1.0
actual brake line , checked.
on your post for code 53?
i look in all FSMs and all say bad ECU or bad ground.
on 8v it mentions grounds
on 16v, it just says this:
1: reset ecu via dome or battery
2:drive
3: still get 53, then bad ECU.
