ok , hot wiring the injector invites 2 things
blowing up the other transistor in the ECU or burning up the expensive injector.
don't do that. ok? please , ( i know other hack zuk sites say to do it but they are wrong)
its a 1 ohm injector, (easy has a kiss to blow up with 12vdc , 1 second , gone)
this ECU has 2 transistors for the injector, one grounds the injector and the other applies 12v to the other side
and it is pulse width modulated so it dont overheat.
so you are killiing it.
its your car ,but why do further damage, if you really burn it up more , your core will be rejected, want that?
http://carfix.stufftoread.com/ECU/injector-drivers.jpg
that is the actual schematic of the THis INJECTOR.
uP = MICRO PROCESSOR PORT/
i do not understand this (me dumb)
The injector pulses at ignition but does not flow fuel while "running"
are you saying.
1: car starts then dies and I see it cutting fuel injection , in some way?
2: or ?? not sure...?
you need a NOID lamp. ( 90% effective on 8v due to dual drivers)
only a scope (DSO) is 100% on this car.
so are you saying the NOID flashes while cranking and when it starts , the NOID dies?
yes?
and that at fast foot cant keep it going , on gas pedal ?
then:
the spark feed back is failing. Ignition noise filter bad. (or bad coil)
or the TPS switch is not signaling idle.
if the TPS does not signal idle (shorted switch) then the car will not idle.
the ecu will be clueless what to do , cuz that is an illegal state.
do you need a noid lamp.?
first thing is that the ECU you have is bad.
replace the 2 , injector drivers.Q101 and Q102 .
your country may have diff ID numbers. in your ecu . (we dont have sunrunners here)
