Old 04-28-2009, 12:43 PM   #1 (permalink)
Badgerfan3121's Avatar
Badgerfan3121 is on a distinguished road
Default Geo tracker transmission instalation
hay guys, i have a 91' geo tracker with a automatic in it, and i was going to make it a manuel. I have a newer 95' for parts, and i was going to put in that manuel. But im not sure if it will work, and what all to do to change it. Is it super hard, or would i be able to do it on a weekend. If i do change it to a manuel, what will it do help out my gas mpg, and would it help me out so i dont rev at 3800 on the interstate. Also what all would i have to change to make it a manuel, would it just be the trany any gears ur anything. Idk Thanks for any replys and help
91' geo tracker 4/4 automatic, new paint job, 16 speakers a rockford 15", flip up LCD touch screen jensen monitor, brush guard, led lighted interior, tinted windows, k&n air intake system, k&n oil filter, , 2" coil spring spacers, 5 1/2'' body lift, shift kit, 2" wheel spacers, cragar black soft 8" rims , bf goodrich tires 235/75/15, custom rock sliders, soon light bar, hood scoops, and 3 inch suspension lift.
Badgerfan3121 is offline   Reply With Quote
Old 04-28-2009, 12:52 PM   #2 (permalink)
cmays03's Avatar
cmays03 is on a distinguished road
by what i have been told its not hard to change over to a manual trans. i hear you can just take the manual pedals out of the one and they will bolt right into the other. just have to cut out for the shifter. other than that i have not done this yet.
cmays03 is offline   Reply With Quote
Old 04-28-2009, 01:10 PM   #3 (permalink)
Ok, thanks for the reply. So it shouldn't be to hard, i'v been talkin to some freinds about it and it seems pretty easy.
Old 04-28-2009, 01:20 PM   #4 (permalink)
cmays03's Avatar
yeah i wish i had done one so i would be more help. but as I have done a lot of fab work on other stuff it does not seem that bad to me. change flywheel on motor while trans is out. I would take some measurements from the from of the trans to the shifter then I would measure the hole in the one that had the manual trans in it for the opening so you can use the boot for the shifter. that way u will have the cut out where it needs to be things like that. I think i was told you can leave the ecu alone but i would hang on to the manual trans one just in case. dont cut the wires that go to the trans i would zip tie them up somewhere in case you decide to put the auto back in it.
Old 04-28-2009, 07:59 PM   #5 (permalink)
deeznutts77's Avatar
Gallery: 4
your going to need the computer too. and at highway speeds i get about 4k at said speed also
To a life consumed by slow decay
Old 04-28-2009, 08:39 PM   #6 (permalink)
Will i need to just have the computer to and it will plug right in where my other one dose, or will their be any diffrent wires that i will need. Do i have to change computers, what if i dont what will happen. thanks
Old 04-29-2009, 08:54 AM   #7 (permalink)
Gallery: 4
yup plugs right in and dont know what happens if u dont
Old 04-29-2009, 08:21 PM   #8 (permalink)
ok thanks for the help.
