ok ,
there is 3 ways to diagnose no cranks.
at least
throw parts and go broke
or take readings, analyse results.
or
hot wire it.
with no meter , or even one of the funny cheap LED sticks that say
"charge and start diagnostics" this leaves us with just one.
my no crank page shows this.
i will detail the steps. (no crank and not even a wimper out of starter solenoid)
1: on the starter is a starter solenoid, my page has a photo of it , see it. see link below.
2: first deside if you want to use a remote starter button for safer and more confortable hot wiring.
3: if not , then see send photo that is the solenoid on the side of the starter.
there are 1 or 2 huge lugs, and one dingly spade faston lug.
that dinky lug is the starter KEYON start line , called ST by suzuki.
next see the outboard big lug , that is the battery cable lug.;
do not ever ground this lug or battery might explode. ok ?
4: put keys in pocket
5: put chocks on wheels rear front edge.
6: car in neutral or park as the case may apply. Xfr case in neutral too. just for safety
7: go down and under to the starter and using a screwdrive (old) jumper the big lug
to the tiny lug. for 1 second.
the starter will spin like mad, very loud and the crank pulley on the front of the motor will spinn about 300 rpm or so.
if this test passes, the stater is good. and the cab wiring is bad.
if it does nothing , then we have a bad starter or a dead battery or very possibly bad battery cables . ( if the charging system is bad the battery will be dead (not bad)
so now is a good time to try a spare or barrowed battery or just jump start the car.)
a voltmeter finds all these things is a couple of minutes.
all this is on my no crank page.
see chapter 2 , no tools section.
Engine-will-not-crank-over
