31 (never lies , unless you disconnected thing KEY ON)
MAP sensor Pressure too high ( illegal low vacuum) (usually grossly in error) 8 valve only.
that is a dead map sensor. vacuum line open, cracked., or sensor unplugged.
filter to MAP plugged.
Throttle body vac. port plugged. ( testing is simple, buying a new one is folly unless you prove it is bad) IMHO
you need to
fess up on the parts on your motor ,that are not original OEM.
any parts not suzuki as shipped from factory.
missing parts, too. Exhaust, CaTconveter mods, headers missing EGR port, etc.
any missing parts, ?
any not OEM.
all it takes is voltmeter and a hand vacuum pump to test the MAP sensor.
or at the least a meter and post the voltage at the output pin , idling.
now tell use what pump fuel in on this car.
what is the name,model and flow rate on this pump.( and pressure specs.)
i told you in PM that the FPREG will not allow , high volume , high PSI pumps, at all.
so tell that story first and what parts are missing or swapped for NON OEM parts.
OEM = Orig. equipment manufacture. this means , parts that came on the car new.
or replaced with Suzuki parts. of correct PN.
map testing
you have 2 problems at least.
im sure.
tell full story , get full answers.
the output of the map sensor at idle is 1.2v DC. that is normal.
with a vacuum guage you can full test the sensor.
it takes , 3 tools, 2 really , hand pump with gauge, and any voltmeter.
(and a needle to back probe the conn)
good luck and
weclome to live post on this forum ,no more PM's , now all can read your issues and contribute.
