92 Geo Tracker Won't Run without pressing Gas - Suzuki Forums: Suzuki Forum Site
Old 04-20-2009, 10:32 PM   #1 (permalink)
jab144 is on a distinguished road
Default 92 Geo Tracker Won't Run without pressing Gas
hello all, my friend has a 92 Geo tracker 1.6L that won't run at all unless you press the gas pedal the whole time any ideas on what this could be? I have replaced spark plugs wire, distributor and cap.
jab144 is offline   Reply With Quote Quick reply to this message
Old 04-20-2009, 10:35 PM   #2 (permalink)
Banned
pandoras box.
sorry.
wont run or wont idle or wont start,
or all 3
3 diff, solutions.too.
Old 04-20-2009, 10:36 PM   #3 (permalink)
Banned
wont start
dies at red lights.
unless you feather gas.?
Old 04-20-2009, 10:37 PM   #4 (permalink)
It won't idle, if you drive it down the road and take foot of gas it will die. It will start and drive but you have to have gas pedal pressed the whole time its an automatic but you have to use both feet, lol
Old 04-20-2009, 11:15 PM   #5 (permalink)
Won't stay running w/o gas pressed... hmm I would buy a NOID and backprobe to see if fuel is being sprayed w/ no throttle (requires a helper to test unless you can get it in the dash under windshield to see it. Otherwise its something with the IAC or anything that jtgh can come up with. Wonder if the dashpot retracts?
95' 2dr Track 4x2 3-speed auto, 8v, 1.6L
93' 2dr Track 4x4 5-speed manual, 8v, 1.6
For quicker assistance please post the YEAR, MAKE, MODEL, ENGINE, TRANS, MILEAGE.
CodyJ is offline   Reply With Quote Quick reply to this message
Old 04-20-2009, 11:59 PM   #6 (permalink)
Banned
TPS IDLE SWITCH IS NOT CLOSED AT IDLE
CALIBRATE IT.
(if it wont close below 300 ohms the tps is bad)
TPS testing
ISC IDLE softare is turned off , if switch is open.
requiring human idle .
Old 04-21-2009, 12:01 AM   #7 (permalink)
Banned
what motor, 8 valves or 16 valves ( 16 valve shouts name on valve cover)
that was top fail, common.
#2 is
clogged up idle passages for air. ISC, IAC, throttle plate blocked with gunk.
cheers
oops forgot #1 , bad bad bad need of a tune up.
Old 04-21-2009, 08:07 AM   #8 (permalink)
Thank you all, I will get on these issues and report back as soon as possible.
Security Question
