too bad you didnt pull the codes before you reset.
get car over 48mph, and do steady cruise for 5min.
then do some coasts down a hill 50mph then drop the gas pedal.
this will cook off both EGR test.
i just did this , 2 days ago on my 96, p0400 set and now one could fixed.
so after selling it to me.
see hole 1, must be fully free on all 96-98 kicks
no reduction allowed. 9mm pistol brush fits perfect
edit:
All the aircleaner stuff , might need moving. .. no big deal.
step 1: front plastic tubes clear of main alum. air tube. (obvious) as is maf. (clean it too)
step 2: unbolt alum main tube.
3: loosen clamps at TB (throttle body) boot
4: remove front side of air tube main hose , this is PCV fresh air i think. at Alum tube end only.
5: pull tube free, and rock it to left.
6: jamp 9mm brush into hole 1. jab , jab A little carb cleaner, sure. bingo thru , now stroke it. 5 times. done.
5 min, to get to it , 1 second clean.
second time blind folded , to see if you can beat my time.
hahahahah
i can do the whole thing in 30 min. end to end.
hint,dont pull any water hoses. ok?
which are they, yes, the ones that dont get hot when engine is hot.
