Alright so I have read alot of the other posts on this board and i believe i may have a pretty good idea of what the problem likely is.
1.6 efi 89
I was driving it off road the other day very low on fuel.
It died and would not fire any longer.
i added more gas and it still would not run.
Towed it home, noticed the fuel pump was not turning on.
Would fire with fuel in the throttle body
hardwired fuel pump, ran but poorly, it was really hard to keep running
That is about where i am at. I plan on getting a new fuel pump, but it ran so poorly when i had the fuel pump wired on. I wonder if there is something else wrong?
The previous owner let it rust out terrible, including the fuel neck. When i bought it from him for only $100 he was using a hose to get gas into the tank. Is it possible the fuel pump just sucked in some rust and died?
Thanks for you advice in advance
Dan
also is this the right pump?
eBay Motors: NEW FUEL PUMP OEM 1989-1991 SUZUKI SIDEKICK (item 390026119959 end time Apr-22-09 13:49:52 PDT)
