Old 04-06-2009, 05:03 PM   #1 (permalink)
deeznutts77's Avatar
Gallery: 4
Default adjusting windows
how do i adjust the windows so they roll up straight! the front of the window is lagging the rear when i put it up
To a life consumed by slow decay
Old 04-06-2009, 05:51 PM   #2 (permalink)
you mean at the same rate ?,zillon hours labor.
all tracks must be cleaned and then sprayed with silicone spray.
any old think grease and dirt removed, not a fun job.
Old 04-06-2009, 05:57 PM   #3 (permalink)
Gallery: 4
yes, same rate. gee thanks just what i wanted to hear! but theres no adjuster on them?
Old 04-06-2009, 06:22 PM   #4 (permalink)
Gallery: 10
HotTommy is on a distinguished road
I just did the window adjustment on my 89 Tracker. Here's how it went. ... First remove the door panel. Beneath the plastic water barrier that covers the door are four screws that secure the window regulator to the door. The screws (two at the top and two at the bottom) go through slots in the door and into the regulator mechanism. By loosening the screws and slideing the top of the regulator toward the back of the car and the bottom toward the front of the car, you will tilt the window so the forward part comes up a bit and the aft part goes down a bit. That should make it so the front and rear of the window reach the top of the door at the same time.
HotTommy is offline   Reply With Quote
Old 04-06-2009, 06:52 PM   #5 (permalink)
Gallery: 4
sweet, ill try it this weekend thanks
Old 04-07-2009, 10:34 AM   #6 (permalink)
Verify weatherstrip in sail [mirror] area is not deteriorated leaving a piece blocking the window channel.
Old 04-07-2009, 01:53 PM   #7 (permalink)
pop cards and look.
Old 04-07-2009, 02:47 PM   #8 (permalink)
Gallery: 4
weather strip is all good allround.
Old 04-14-2009, 12:07 AM   #9 (permalink)
Don B is on a distinguished road
Sorry, but what does "pop cards and look" mean? Please translate.
Don B
Don B is offline   Reply With Quote
Old 04-14-2009, 12:16 AM   #10 (permalink)
Don B
The inner door panel is often referred to as a 'card' or a 'skin'. He was saying to remove them & look to see what adjustments there are.
Pioneer Sound system
fuzzy1 is offline   Reply With Quote
